Stator socket and plug
Old Jan 21, 2019 | 08:55 AM
gizmops's Avatar
gizmops
6th Gear
Default Stator socket and plug
Hi all, I am trying to source and replace the stator socket and plug. mine is 27 years old and gone hard and is also damaged with arcing. Any clues where I can buy one please.<br />Its for 1992 Electra Glide FLHTC.
Old Jan 21, 2019 | 09:36 AM
Bingee's Avatar
Bingee
Maybe you should be looking at replacing that 27 yr old stator. They don't last forever.
Just replacing the plug doesn't bring them back to life. Check these guys out. They
sell the best there is.
http://www.cycleelectricinc.com/
Old Jan 21, 2019 | 09:40 AM
PDB17UltraRG's Avatar
PDB17UltraRG
Thats a great idea get with the times older parts are harder to fine it may be upgrade.
Old Jan 21, 2019 | 10:00 AM
gizmops's Avatar
gizmops
6th Gear
Thanks for your reply. The bike has only done 37000 miles and stator is working fine " at the moment". Certainly worth exploring, I will look at cost and labour.
Regards
Old Jan 21, 2019 | 10:02 AM
gizmops's Avatar
gizmops
6th Gear
Thanks for your reply. Exploring replacing stator as suggested. Found standard and higher amp. Next question which one. Decisions.
Old Jan 21, 2019 | 10:03 AM
gizmops's Avatar
gizmops
6th Gear
Thanks. Next question, standard or higher amps. Decisions. lol
Old Jan 21, 2019 | 11:22 AM
Bingee's Avatar
Bingee
The standard stator is 32 amp. Unless you have added a lot of electric accessories there is no need for more
amps. The reliability of stators is more dependent on the condition of the windings than mileage. If there's been
arcing that may have caused heat stress on them. Replacing the stator on a '92 is fairly easy.
Old Jan 21, 2019 | 05:15 PM
Musician's Avatar
Musician
According to the parts department, the plug and socket are NOT replaceable. It is an entire unit, so if you have a bad plug and socket, you gotta replace the stator. According to Harley. Since the lead wires are cast into the stator, they're probably correct.
Old Jan 21, 2019 | 10:07 PM
hardheaded's Avatar
hardheaded
Is it the regulator plug , which is female or the stator plug which is male ? If it's just the regulator plug i would find a bad or used one and cut it off and splice it together or just replace the regulator.
Old Jan 22, 2019 | 11:32 AM
pjb's Avatar
pjb
Since you're brand new to the forum, it should be pointed out that you may be better off addressing this in the Evo sub forum.
