Shifter
Old Mar 1, 2019 | 10:39 AM
Lukas2336's Avatar
Lukas2336
Default Shifter
A friend of mine has an older road king (06 or 07 I think). The shifter didn't return up one day. I know there is threads about the ratchet pawl spring causing this issue but I can't find it. If anyone can reply with a link, or other ideas on what could cause this it would help. Thanks,
Chris
Old Mar 1, 2019 | 10:48 AM
touchdown's Avatar
touchdown
Maybe a shifting arm , you should be able to look at it and tell, if not maybe take it to a shop because your over your head.
Old Mar 1, 2019 | 11:20 AM
tideguyinal's Avatar
tideguyinal
Mine was all gunked up with crud. I cleaned mine out and it works like new.
Old Mar 1, 2019 | 11:41 AM
btsom's Avatar
btsom
The forward shift shaft can get dry (no lube) and become prone to bind and even a properly working centering spring can't return the shift linkage to center. Lube that front shaft and the linkage pivots before going into the transmission. It just might be that easy.
Old Mar 1, 2019 | 01:34 PM
Down South's Avatar
Down South
Chris
Here are some search links that may help.
Shifter pawl spring.
Old Mar 1, 2019 | 01:54 PM
Lukas2336's Avatar
Lukas2336
Thanks for the help guys.
Old Mar 1, 2019 | 04:17 PM
Studlintsean's Avatar
Studlintsean
Check that the shift linkage didn’t slip from the spline. Known Harley problem and happened to me twice before I replaced the entire shift rod and linkage.
Old Mar 1, 2019 | 07:47 PM
14GuineaPig's Avatar
14GuineaPig
This thread might help
https://www.hdforums.com/forum/evo-c...wl-spring.html
I had something similar happen to my 2002 FLHTCUI, I could shift it but I had to keep pressure on the shift lever to keep it in gear. On my bike they replaced the "Spring, Detent Arm" (P/N 33374-00). It was a $1.50 spring and 3.75 hours labor to replace it.
Old Mar 1, 2019 | 10:25 PM
groupw's Avatar
groupw
....... so, not a cheap spring, eh ?
Old Mar 3, 2019 | 10:00 AM
14GuineaPig
A $50.00 spring … that was the deductible I had to pay, the rest was covered by ESP.
