Need help bros
Old Mar 27, 2019 | 07:58 AM
FastHoss's Avatar
FastHoss
Default Need help bros
My new LED head lights are great , nice and bright. I think makes a big difference in drivers seeing me. Down side is in the fog can't see so good, too bright. What do you suggest,ride to work most days sometimes foggy.
Old Mar 27, 2019 | 08:32 AM
grbrown's Avatar
grbrown
Exclamation
Your problem in fog suggests you have used an unsuitable LED bulb. Drivers can see you because your new light is dazzling them! Unfortunately it seems that many manufacturers of them make little effort to ensure their LED bulbs will work properly in a traditional reflector. You are suffering from 'flare', in which light is reflecting upwards into your line of vision, probably because the LEDs in your new 'bulb' do not coincide with the focal point of the reflector. I won't use them and bought a trio of Trucklites for my Glide. They ain't cheap, but the conform to the correct regulations and have a great beam pattern.
Old Mar 27, 2019 | 10:27 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
One of the things I like most about my Truck Lite P7 on my 'King, like the headlights on my newer vehicles, is the clean line of the lights when on dim. Bright fills in above the line, but bright adds to glare in fog. Graham my have hit the nail on the head for you - that bulb might be unsuitable for your needs.
That clean line just wows me every time I drive one of my newer vehicles, it is more defined than the TLP7, but it is still there. If you have very much light going up on dim, there's your glare.
Old Mar 27, 2019 | 10:33 AM
grbrown's Avatar
grbrown
Thumbs up
You chaps got the Chevrolet Chevette, while we got much the same car as a Vauxhall (GM in the UK) Chevette, with similar recessed sealed beam headlights. That recess was a real pain as it caused the same problem - reflecting light upwards to illuminate fog or light rain. I painted mine matt black which helped a lot. The cause was different, but the effect much the same as the OP is suffering.
Old Mar 27, 2019 | 09:05 PM
NWTruck's Avatar
NWTruck
Here in the PNW we have fog quite often, my TruckLite trio works well for that.
Old Mar 28, 2019 | 07:38 AM
TheGrandPoohBah
Headlight technology has come a long way.
Perhaps some manufacturers cut cost in that area and cover it up with "It's an LED Light".
Old Mar 28, 2019 | 07:48 AM
Slowpoke62's Avatar
Slowpoke62
You might try angling them down more. Upwards reflection can be adjusted out on most lights.
Old Mar 28, 2019 | 08:40 AM
itsmf's Avatar
itsmf
Default Leds
Its position as much as light,try fog lights mounted to ur brake calipers as in Motolights.
Old Mar 28, 2019 | 09:25 AM
SBates08's Avatar
SBates08
So where are you guys getting that the OP installed a LED "bulb"? Am I missing something, he did say LED headlight correct??
As far as the TruckLites go, I have all 3 in mine and they're all adjusted correctly and I have the same issue in heavy fog. Almost a complete white out at times. The heavier the fog the worse it is.
Old Mar 28, 2019 | 03:32 PM
470004's Avatar
470004
Fog lights.
