Thunderheader
Old Apr 16, 2019 | 04:54 PM
23Seven's Avatar
23Seven
Default Thunderheader
I just bought a used Thunderheader off of a 2012 RG.
This should be a fit for an 09 King right?
Only 2k on the pipe and he’s giving it to me for $500 cash!
Old Apr 16, 2019 | 06:43 PM
browndog2u's Avatar
browndog2u
Ya same thing. Enjoy! Love my thunderheaders!
Old Apr 16, 2019 | 09:06 PM
23Seven's Avatar
23Seven
Anyone have suggestions for good exhaust gaskets?
Also... Should I bend a couple tabs in the baffles? I was thinking of bending 2 as this was supposed to up Torque a bit and help the torque dip??
Old Apr 17, 2019 | 12:09 AM
23Seven's Avatar
23Seven
Well damn...
After further investigation I discovered that 09’s have 18mm O2’s and 10-16’s have 12mm that are located in a different spot.
The pipe I was going to pick up was from a 2012. Back to shopping again!
Old Apr 17, 2019 | 12:19 PM
04ctd's Avatar
04ctd
wont the slip fit muffler fit on your existing pipe/pipes?
Old Apr 17, 2019 | 02:14 PM
23Seven's Avatar
23Seven
Yes if that’s what I was looking for.
This was about a great deal on a full 2:1 exhaust. I already have a catless. Headpipe and slipon mufflers.
Old Apr 17, 2019 | 03:14 PM
browndog2u's Avatar
browndog2u
Ya sorry I forgot they changed that year. You could weld in new inserts & plug the others??
Old Apr 17, 2019 | 03:32 PM
hew's Avatar
hew
You can get 18mm to 12mm adaptors for less than 10 bucks.
Old Apr 17, 2019 | 03:36 PM
23Seven's Avatar
23Seven
Sure but they are not located in the same spot on the pipe.
Its my understanding that this will not work with the ECM??
Old Apr 17, 2019 | 03:39 PM
hew's Avatar
hew
Also I screwed that up. It would be 12 to 18mm. You would have to weld new bungs on. Still would be cheaper to do though.
