08 flhtcu rear brake switch
The job was not that hard. Technically you have to bleed the rear brake system after install. I found very little fluid loss as I switched it pretty quick, pedal was still firm so I blew off the bleed!
Mine switch was replaced for free on recall some years back might want to check it out.
HARLEY DAVIDSON TOURING ( 06/06/2008 – 16/09/2011) DEFECT: The rear brake lamp switch may become exposed to temperatures that degrade its performance. This condition may affect brake lamp function and /or cause a brake fluid leak through the rear brake switch affecting rear brake performance.
Remedy: Recall the machines that are likely to be affected to check and where necessary replace the rear brake lamp switch using the recall kit.
Recall Launch Date: 23/01/2012 Recall No: RM/2011/031e was replaced for free check it out.
