Engine Fitment Question
Old Jul 20, 2019 | 11:47 AM
LeeC_Mo's Avatar
LeeC_Mo
Default Engine Fitment Question
I have a 2007 Streetglide with a 96" block. Would a 2016 motor mount up to the 2007 frame?
Old Jul 20, 2019 | 12:40 PM
Biggzed's Avatar
Biggzed
It should. S&S crate motors are stated as '07-'16 fitment on their website.
Zach
Old Jul 20, 2019 | 04:47 PM
cncmike's Avatar
cncmike
I’m pretty sure all the 96 and 103’s are the same as far
as interchanging
Old Jul 20, 2019 | 06:35 PM
lp's Avatar
lp
Might have to remove the forward top engine mount and install the 2007 style in the center of the heads but that shouldn't be a problem.
Old Oct 9, 2019 | 02:53 PM
LeeC_Mo's Avatar
LeeC_Mo
Just an update. 2016 motor bolts up just fine. Primary all fine etc. But....Theres ALWAYS a but! I switched to the new Screaming Eagle Compensator and had major issues on the primary side.
Just a quik what happened. In 2007 the Stator was a bolt in and go type stator. No spacer between rotor and inner stator as 2016 has. I found this out the hard way! Melted stator and a costly mistake. But the engine and stator is in and all runs like a scalded *** dawg now. Required the spacer $20 and a new stator.
Thanks for all the advice fellas.
lordgrape
Engine Mechanical Topics
Apr 10, 2018 04:41 AM
TO34
Nov 14, 2017 10:52 AM
jbyrd1173
Jul 7, 2016 11:18 AM
davlyo
Nov 1, 2009 12:17 AM
IceHeritage
Dec 30, 2007 10:38 AM
