Tapping at Start
Old Oct 6, 2019 | 04:14 PM
dmasonnj's Avatar
dmasonnj
Default Tapping at Start
I have a 2012 Street Glide with 75K miles. When I cold start, it has a noticible tap. If I ride it for a mile, get gas, and then restart the tap usually goes away. Any thoughts? Cam tensioner?
Thanks for your comments.
Old Oct 6, 2019 | 04:50 PM
EG-2006's Avatar
EG-2006
Just a guess-Failing lifter?
Old Oct 6, 2019 | 05:13 PM
hattitude's Avatar
hattitude
Without hearing it... a failing lifter could be a good guess because the 2012s have the crappy "C" series HD lifters.....
But also, a tapping when cold that goes away when warm, could be an exhaust leak...... as well as several other possibilities....
Better to do some diagnostics rather than to guess and just throw parts at it....
You need to locate, as accurately as you can, the location of the sound... use a stethoscope if necessary.... The location will give a good clue, to narrow down the choices, and where to go from there....
Old Oct 6, 2019 | 07:31 PM
Zerk's Avatar
Zerk
lifters?
Old Oct 7, 2019 | 07:37 AM
grbrown's Avatar
grbrown
Wink
Or find a local indy to diagnose things for you! That can be a darned sight quicker way to find the problem and put it right.
Old Oct 7, 2019 | 07:48 AM
Zerk's Avatar
Zerk
Some people like having other people do it for them. I don't have one, but a mechanis scope might help.
I had noisy new lifter for thousands of miles in the morning. Was concerning thousand of miles from home, on a engine I built myself. Can't explain it, but it went away
Old Oct 8, 2019 | 10:18 AM
Puglia10's Avatar
Puglia10
if its a lifter, replace it quickly! mine tapped for a minute one cold start during a trip and the second day it came apart and went through my oil pump, cam plate, and took out the cams too...$1,500+ mistake.
Old Oct 8, 2019 | 02:25 PM
cwsharp's Avatar
cwsharp
The lifters drain down the oil in them from sitting. Typical Harley... nothing to be done AFAIK. Not supposed to hurt anything according to HD.
Old Oct 8, 2019 | 04:51 PM
hattitude's Avatar
hattitude
Maybe typical Harley crappy "C" series lifters.........
I'm sure lifters leak down to a point, and I suspect it's not the end of the world if they clatter a little at start-up, as long as they pump up quickly and the noise goes away....
But having said that... of the 2 shovelheads, 1 EVO, and 4 twin cams that I have owned.... not one ever had the lifters leak down to the point where they made any noise as they had to pump up when I started the engines.... OK, the shovel heads didn't have hydraulic lifters, but that's beside the point...
One year I had an injury and a couple back surgeries, I only managed to ride 3 times that year.... with months in between rides.... not a peep from my lifters of my '03 twin cam at start up...
So while it may not be a terrible thing, I'd change out the lifters it my bikes were doing it....
D777
Engine Mechanical Topics
Apr 28, 2019 07:16 AM
Ruprecht
May 7, 2017 08:26 PM
harleyflhx
Aug 12, 2012 07:51 PM
fryeca
Nov 23, 2007 06:54 AM
