Spray throttle cleaner recommendations
Old Dec 29, 2019 | 10:24 PM
selandbe@gmail.com's Avatar
selandbe@gmail.com
Default Spray throttle cleaner recommendations
I have a 2001 Road King Classic with fuel injection and a Magnetti Marrelli throttle body ... and the throttle sticks a bit ... I have read that your not supposed to use throttle spray cleaned on Harleys because of the sensors ... is there a spray throttle cleaner that IS recommended and safe to use? Thanks for the help.
Old Dec 29, 2019 | 11:21 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
A Mass Air Flow cleaner will work just fine as it doesn't leave any residue that can possibly jack up the sensors.
Old Dec 30, 2019 | 06:13 AM
CSMHOG's Avatar
CSMHOG
I use CRC Mass Air Flow Sensor cleaner everytime I do my scheduled maintenance and I've never had an issue, you can pick it up at near every auto parts store. How do you know it's the throttle plate and not caused by cables or something else in the control housing near your throttle tube?? Could be something very simple such as the throttle lock screw was turned in a bit too much. Not trying insult your intelligence at all here, just offering up some suggestions.
Old Dec 30, 2019 | 06:59 AM
Geoff1200's Avatar
Geoff1200
Yes, will say right on the can "sensor safe" Use and old toothbrush, do this before ya put in new plugs...
When's the last cable service and adj.?
Old Dec 30, 2019 | 07:47 AM
btsom's Avatar
btsom
There is a chance it isn't the sensor but the twist grip itself. Try removing the twist grip, clean the handlebar and the inside of the grip and apply a very thin coat of grease to handlebar and reinstall the grip. I have no experience with MM throttle sensor but testing it for binding should be much the same as for the current versions. remove the grip and try twisting the end of the sensor by hand or with a tool, such as channel lock pliars using a very light squeeze and rotate the sensor. If you feel it binding,the cleaner might help but in my case, replacement was the only choice that worked. Have no idea if MM sensors are still available. A conversion to carburetor and cable throttle may be in your future.
Old Dec 30, 2019 | 09:02 AM
caulk04's Avatar
caulk04
2001. Cable throttle.
TBW started in 08 (or was in 07 with the 96 and 6spd?)
Old Dec 30, 2019 | 09:58 AM
im's Avatar
im
What do you mean by "sticks a bit" ?
A common cause of slow throttle return or sticky throttle return is caused by the throttle grip.
Take a look at grips...are they factory original?
Sometimes folks will install new grips but then place the clamp portion either pulling towards bike center line or pushing towards outside and that causes a stick point at grip.
That stick point causes a failed return.
It would be unusual or less likely for throttle body to sticky.
Of coarse, i would imagine that you reviewed the throttle friction friction screw (The plastic star shape thing that locks throttle)
A throttle pull cable that has a lost a few strands near terminal ball at throttle sleeve could also cause a failed smooth return.
Old Dec 30, 2019 | 01:04 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
So too an overly tight cables. There needs to be some cable slack.
And, of course, carbon and crud on the throttle blade.
jsvt184
Nov 26, 2015 02:00 PM
Kraken207
General Topics/Tech Tips
Aug 27, 2015 10:44 AM
Doc o
Mar 6, 2011 03:39 PM
relli
Sep 19, 2010 07:15 AM
NiteOwl
Aug 14, 2009 02:21 PM
