Cleaning throttle body?
Old Mar 5, 2011 | 11:16 AM
Doc o's Avatar
Doc o
Default Cleaning throttle body?
Before I screw something up I want ask.
I replace the air clean on my 05 RK and noticed
the throttle boby was pretty dirty.
Woud you clean it like on a car, spay with throttle body cleaner.
Or do you do it another way?
I know this may be a simple question but I sure as he$$ don't want scew something up.
Thanks
Don
Old Mar 5, 2011 | 03:52 PM
Gearhead3's Avatar
Gearhead3
I've used carb cleaner on mine before with no apparent ill effects. Just don't go nuts with it. (too much "spritzing" and it can get into the cylinders and may cause problems on restart) It's also a good idea to open the throttle blade and clean the area behind it. Usually by the time you get everything buttoned back up any excess has evaporated and you're good to go. Make sure to cover the area around the throttle body with an old towel (or similar) so any splash doesn't get on the paint.
Old Mar 5, 2011 | 04:09 PM
nvsteve's Avatar
nvsteve
I use carb cleaner. Also open the butterfly and clean on the inside. Mine was dirty.
Old Mar 6, 2011 | 03:03 PM
Doc o's Avatar
Doc o
Thank you
Old Mar 6, 2011 | 03:39 PM
Bill03E's Avatar
Bill03E
I get a rag very wet with lacquer thinner, and wipe it out real good, I have used throttle body cleaner as well.
jsvt184
Nov 26, 2015 02:00 PM
rapp76
Jun 26, 2013 08:32 AM
Gliden
Exhaust System Topics
Apr 24, 2011 01:23 PM
relli
Sep 19, 2010 07:15 AM
NiteOwl
Aug 14, 2009 02:21 PM
