Q - Throttle Body Cleaning
Old Aug 7, 2009 | 06:28 PM
NiteOwl's Avatar
NiteOwl
Default Q - Throttle Body Cleaning
On my car I have some spray that I use to clean the throttle body, is this a good idea for the throttle body between the 2 cylinders perhaps every time one changes oil and inspects the air cleaner?
Old Aug 11, 2009 | 11:03 AM
jsbridgew's Avatar
jsbridgew
good question... i was wondering the same thing....took my air filter off to change and the throttle body was filthy....no doubt due to running a bit rich, but can it be cleaned?
Old Aug 11, 2009 | 12:10 PM
StreetGlider56's Avatar
StreetGlider56
Some throttle bodys are coated on automobiles and the spray will remove the coating, not sure on the Harley..
Old Aug 11, 2009 | 01:08 PM
m3breecer's Avatar
m3breecer
I clean mine when ever I service the K &N airfilter
Old Aug 11, 2009 | 02:01 PM
xmeter's Avatar
xmeter
Not all sprays will remove the coating. Just look for one that is made for the newer injection systems.
Old Aug 11, 2009 | 07:28 PM
Buddha2's Avatar
Buddha2
I don't think it's from running rich as the injectors are behind the throttle body. I think what is happening is the breathers are feeding oil vapors into the throttle body as is intended.
Old Aug 11, 2009 | 09:41 PM
NiteOwl's Avatar
NiteOwl
Certainly hope that's not the case, I have done mine, I like the results and will most likely continue this procedure every time I do the air breather.
Old Aug 11, 2009 | 09:47 PM
armyof1's Avatar
armyof1
i do my tb's every 4-6 months. or whenever she isnt running quite right. same on my Vic.
Old Aug 14, 2009 | 12:42 PM
jsbridgew's Avatar
jsbridgew
what do you guys use to clean it?....any product in particular?
Old Aug 14, 2009 | 02:11 PM
NiteOwl's Avatar
NiteOwl
I used a product called ( "kleen-flo" air intake kleen ) Not sure if these products are mostly the same.
Says its safe for Throttle bodies, valves and idle air control valves and sensors.
Worked great!
