Road King shifter problem.
Old Mar 8, 2020 | 12:13 PM
Nevada Jim's Avatar
Nevada Jim
Default Road King shifter problem.
An issue began today with my '13 RK.
On 2 occasions, I shifted from 1st into neutral instead of 2nd gear.
I can shift into 2nd if I apply an unusual amount of effort. Any idea why this happens and how big a job it would be to correct.
Thanks in advance for any helpful replies.
NJ
Old Mar 8, 2020 | 01:05 PM
xcbullet's Avatar
xcbullet
When mine started doing that, after trying adjustments to shift pawl, I ended up rebuilding with a Baker master rebuild kit. That was about 60,000 miles ago and 4 years. Shifts great still. Two parts in the kit didn't work though. But the shift kit that comes with it is awesome. Not sure if they make it for that year. Also I've been running red line shock proof after rebuilt
Old Mar 8, 2020 | 02:38 PM
dave grider's Avatar
dave grider
Try adjusting your clutch per the manual
Old Mar 8, 2020 | 02:56 PM
Buster's Avatar
Buster
if you are using a heel shifter, make sure it's not too low, and hitting the footboard,
Old Mar 8, 2020 | 06:11 PM
eighteight's Avatar
eighteight
Look for slop at the rear linkage arm that moves the trans shaft
these are notorious for becoming loose.
as arm replacement requires primary removal many owners remove the bolt and tighten the NEW bolt within a ft lb of its life
Old Mar 8, 2020 | 08:47 PM
dickey's Avatar
dickey
Don't understand the problem. Sounds normal to me.
ninety4
Dec 8, 2012 09:12 AM
Jflores73
Jul 5, 2010 07:42 AM
Magnum 61
Jun 11, 2010 06:29 AM
12Gauge
Mar 2, 2010 10:51 PM
goldthwaite
May 5, 2009 06:51 AM
