Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Shifting problems
Old Jul 4, 2010 | 12:07 PM
Jflores73's Avatar
Jflores73
1st Gear
Default Shifting problems
I'm having problems with my tranny not wanting to stay in gear when shifting. If you hold pressure on the shifter it does fine otherwise it acts like it falls into a neutral position. Any suggestions?
Old Jul 4, 2010 | 01:24 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Model and year ?
Old Jul 4, 2010 | 04:21 PM
Jflores73's Avatar
Jflores73
1st Gear
2002 Road King Classic
Old Jul 4, 2010 | 06:09 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Make sure the linkage moves freely and does not bind. Check the shift lever at the transmission, make sure it is secure to the shaft, no looseness at all.
Old Jul 5, 2010 | 07:42 AM
Jflores73's Avatar
Jflores73
1st Gear
Thanks I checked all that. The shift lever going into the trans. moves in and out about a 1/4 inch shaft and all.
Magnum 61
Jun 11, 2010 06:29 AM
davidtn
Aug 25, 2009 03:45 PM
davidtn
Aug 11, 2009 02:17 PM
goldthwaite
May 5, 2009 06:51 AM
Jmehaff
Jul 29, 2007 12:07 PM
