Electra glide Speedo question
Old Mar 10, 2020 | 09:04 PM
Shaun Baynum's Avatar
Shaun Baynum
Stage II
Default Electra glide Speedo question
My 99 Electra glide has a 21" front wheel installed by previous owner. The mechanical Speedo drive quit working and now I need a new one. Does anyone know if the ratio changes, I believe it's 2240:60 with a stock 16" wheel. I would like my speedometer and mileage to be correct. Any info would be appreciated. Been searching all over online and can't figure it out.
Old Mar 10, 2020 | 11:03 PM
BigDogIdaho's Avatar
BigDogIdaho
It's overall tie size that will decide if it needs changed or not.
I.E. if the stock tire is 23" tall with a 16" rim, & your new tire is 23" with a 21" rim your tire is still 23".
I'm just pulling those numbers out of my *** for demonstrative purposes though.
You will need to figure out stock tire size vs current tire size.
Old Mar 11, 2020 | 01:11 AM
EVOrider's Avatar
EVOrider
If your transmission has the cut out for the speed sensor.....you run a digital speedometer with more options.
The Road Kings already has the cut out. All 2000+ Electra Glides has the cut out.
I have only seen THREE ‘99 Electra Glides come from the factory with the cut out with a block off plate installed. You might have one of these rare ones.
JONESER900RR
EVO
Jun 4, 2019 04:25 PM
HD HERB
Dec 9, 2012 11:15 AM
IFID95flht
Wheels/Tires
Aug 7, 2012 06:14 PM
kappyk66
Jan 6, 2010 12:12 PM
tom1340
Aug 7, 2005 12:46 AM
