Bars
Old Mar 14, 2020 | 01:22 PM
hdman6's Avatar
hdman6
Question Bars
I have a 2012 FLHTCUSE7 ultra. I have the stock bars on it (8" i'm pretty sure) U'm tall 6'2 and have issues when turning tight turn of the bars hitting my knees. I have to move my knee out to make a tight turn thus throwing off the balance etc. I really don't see enough room available moving them forward. they would be touching the fairing. Looking for just a little bit higher so maybe 10" bars would work hopefully using same cables etc. Any ideas on the cost to have it done? I do have the service manual and parts book and do some of my own maintenance. Just not sure about the throttle etc
thanks Jeff
Old Mar 14, 2020 | 01:47 PM
dawg's Avatar
dawg
Cost is crazy what dealers charge for bars. If you got Khromewerks sweepers you could use everything and only need a new $40 clutch cable and $5 tranny side cover gasket. The bars are $110. Do it yourself and take your time. Dealer will tell you about 6 hrs labor.
Old Mar 14, 2020 | 06:35 PM
pyuchem's Avatar
pyuchem
I did bars once. Went with Khromewerks 2+2 narrow. Spent about $1000 and I'm still not happy. My lower back and neck hurt after 30 mins on bike. Looking back I shud have just went with Heliers bars. Yes they are expensive around $700. But once you get heli they have so much adjustments I think you don't need any other bars. I looked at them and said damn they are expensive, guess what ? Now I'm just where I was in the beginning. If I had just went with Heli I would have saved money in the long run. Few people may not like their design.
Just called an Indy shop in Spokane, WA they gave a rough estimate of 3 to 8 hrs of labor. That means anywhere between $300 to $1300 for bar swap. And that is not even dealer. When asked why so much ? He said he has to take the tank, fairing and other things off of the bike due to ABS module or something. I have seen bar swap at bike week and they didn't have to take tank off. I have seen them do in less than 2 hours at bike week.
Anyone here in eastern WA that can help me swap the bars ? LOL!!!
Old Mar 14, 2020 | 06:47 PM
GreenMonster's Avatar
GreenMonster
Watch some YouTube videos . I’m going to do the soon myself .
Old Mar 15, 2020 | 02:53 PM
Angryman's Avatar
Angryman
I put Khromewerks 10" bars on my 08. Got them from Dennis Kirk. Those and some new poly riser bushings cost me $100. Did it 3 summers ago and love it.
Old Mar 24, 2020 | 09:40 AM
Harleylife1's Avatar
Harleylife1
I know from experience with 10" wild 1 chubby bars you can get away with your stock stuff. Cost then would depend on the dealership or whoever does the install.
Old Mar 24, 2020 | 01:24 PM
hdman6's Avatar
hdman6
I am planning on the wild1 chubby 10: bagger apes wo578. I found a pic on the chubby site of my bike with them installed. Looks perfect. I just have to order them and then set up the install thanks for the help Jeff
Old Mar 24, 2020 | 02:38 PM
TXNT's Avatar
TXNT
$500-$1500 is the range I discovered. I did Kromewerks 2+2 on my SG and like them but Im only 5'10. Dealer charged me $500 but it was between Christmas and New Years and they needed something to do. Shoulda done helibars and been done with it one time. I put helibars on my Goldwing and love them.
Old Mar 24, 2020 | 04:22 PM
ramblin5's Avatar
ramblin5
Not sure why your Indy would quote 3-8 hours. I've had helis put on by my Indy 3 different times. Took him 1.5 hrs each time. $140. And that included the heated grips. Tank does not come off.
Old Mar 25, 2020 | 01:59 PM
Crabchuck's Avatar
Crabchuck
I just put 10" Yafee Monkeybars on my '18FLHX. Wasn't too bad of a job. I extended my own wiring, so that was a savings. With 10", I didn't have to extend my clutch or brake lines. You might be different. I did price what it would cost, including their superclamp and new lines and harley wiring extensions. It was about $900 just for parts. Yafee has a deal going on right now, so I got my bars and the clamp for about $440 all in. The rest was just labor and some shrink tubing. Probably a 5 hour job total due to all the internal wiring.
