AIM Light force
Old Aug 19, 2020 | 02:25 PM
royston's Avatar
royston
Default AIM Light force
Hi all,
So my AIM LF2 let go yesterday - installed just a year ago and around 5k miles......pretty **** performance frankly, though the “nice” people at AIM have offered to mail me a new replacement seals.
My question is given 1 year is not good and something I don't want to make an annual maintenance issue How many have actually repaired and then gone onto have a decent time with it....simply not sure if im wasting my time and better off going to another manufacturer or even oem....?
Thanks
R
Old Aug 19, 2020 | 03:13 PM
Redbeard719's Avatar
Redbeard719
Curious to hear the feedback you get on this. I don't know if I could ever really trust it if it was repaired/new seals installed.
Unfortunately it's cases like yours that steered me to another manufacturer from the onset as I went with a Mueller Hydro Clutch instead. So far I have about 3k miles on it with no trouble.
Best of luck on getting this sorted out and deciding what to do!
Old Aug 19, 2020 | 03:33 PM
woodreaux's Avatar
woodreaux
Installed my AIM LF2 on 8-1-19 after the LF1 failed in late July with about 5,500 miles on it. At present the LF2 unit has over 16,000 miles with no issues with engagement beginning about an inch off the bar. I’m probably going to change the fluid soon as an inspection-maintenance concern.
I may not be interested in trying LF3 if this LF2 fails. I don’t want to spend another $300 for a reduced clutch pull that (IMO) HD could have addressed from the factory.
Old Aug 19, 2020 | 04:12 PM
lp's Avatar
lp
I'm going on a year and maybe 5 months on my replacement which had the new seals. No issues. If this one finally does crap out I'm probably getting the Rekluse.
Old Aug 19, 2020 | 09:46 PM
ChicagoBikeDriver's Avatar
ChicagoBikeDriver
Have 8K miles on a LF2, installed in April 2020, all good so far. Have my eyes crossed, along with fingers and toes hoping it hangs in for 30K plus miles.
Very much enjoying the combination of LF2, and 3/4" reduced reach lever combination, but I digress.
Roy, I hope your back on the road ASAP!
Old Aug 19, 2020 | 11:14 PM
NorthWestern's Avatar
NorthWestern
Originally Posted by royston
Hi all,
Thanks
R
That's cool they are fixing you up. There are so many that have had problems that I went with Muller.
There are plenty of happy AIM customers, and I am one of them. I love my SDR, just decided to not risk it on the slave cylinder.
Hopefully, this is the last one you will have to replace. I hate pulling that damn exhaust.
Good luck, man!
Old Aug 21, 2020 | 02:01 AM
RiderX's Avatar
RiderX
I had one one my 2017 Street Glide Special that had about 15K miles on it with no issues. I put one on my 2019 CVO Street Glide and had to replace the seals around 4500 miles. I think they finally got it right with the new seals and the Light Force 2. They acknowledged that there was a problem with the old seals and sent me new ones for free.
Old Aug 31, 2020 | 05:43 AM
royston's Avatar
royston
Default Update - dont buy an AIM salve
Ok - so some of you guys get no ok with one of these and this is my personal experience -
AIM clearly got the model 1 wrong and corrected it with model two, a rife search on the internet does indicate a high failure rate with these also, whilst the casing looks and seems fine the problem lies with the seals, these being so bade failure seems common to the point AIM will send you out a free replacement seal kit....the issue here though is why you should even be contemplating replacing slave seal gaskets after just a few thousand miles, (and its my reckoning that a year on we will be seeing yet another replacement), after all its agg replaying this thing no?
If you are an international buyer AIM ask you to pay postage, not cheap between states and europe!!
Overall piece of **** kit and poor customer service - there are better products out there.
I wont go into Rekluse as I havnt had one however when this AIM unit blew I switched to a “Muller” unit, made right here in Europe. Now by contrast a google search does not reveal failures, actually I havnt found one...perhaps as it uses the oem seals and oem units dont often leak this is the sweet spot.
Take my advise or leave it and this is particular if you are outside of US - dont buy an AIM there is at least one better alternative out there...
Old Aug 31, 2020 | 09:11 AM
hattitude's Avatar
hattitude
I have the Muller Hydro clutch and so far it has worked well with no problems...
I was considering the AIM, but at the time, for a twin cam, you needed to switch not only the clutch slave, but you had to use an adapter for your cutch line fitting. You also had to change the master cylinder... That made the AIM much more expensive and more install work than the Muller... so I went with Muller
I remember reading that AIM had an issue with some early units reference the seals... since I didn't use it, I didn't pay much attention, but I thought that seal issue was dealt with on newer AIM units...
In any case, if you don't want to use/try/deal with AIM, there are now other choices out there...
SnoRider
Jul 13, 2016 06:07 AM
BigMESA
Mar 18, 2014 12:58 PM
Jbco2
Oct 10, 2013 12:30 AM
Dafy
Jun 26, 2012 09:19 AM
