Leak Down Test
Old Dec 19, 2020 | 01:50 AM
General Hangover's Avatar
General Hangover
That's crazy.....
In my 2001 & 2003 Service Manuals it calls for a max of 10%....
Was better quality in the good ole days... 😉
Old Dec 19, 2020 | 08:11 AM
Vernal's Avatar
Vernal
2015 Manual says to run engine to normal temp. 10%
2020 manual has no mention of engine temp 25%. It would be interesting to see results from a warm and cold M8.
Old Dec 19, 2020 | 10:07 AM
skydude426's Avatar
skydude426
My 2012 service manual calls for a warm engine and 10% maximum leak down. I’m curious to hear opinions from people with more experience doing leak down testing on many engines. It’s interesting that the twin cams call for 10% or less and the M8’s are up to 25%. Here’s another thing I’d be interested to hear what experienced mechanics would have to say about this.
My primary is disassembled waiting for parts. I plan on leak down testing my engine both warm and cold to see the difference. It’s a 2012 twin cam that’s been bored to a 107.
Old Dec 19, 2020 | 10:35 AM
d_slat's Avatar
d_slat
Like many other companies, HD is loosening their QC. By doing so, they'll save some money in warranty repairs. They are known to have problems with cylinders bored out of round, and instead of fixing the cause of the problem, this is the path they chose.
Old Dec 19, 2020 | 01:40 PM
hattitude's Avatar
hattitude
Just like when they bumped up the allowable runout of the twin cam a few times until it reached 0.012" allowable runout around 2012ish.... All about money.... $$$$$
Old Dec 19, 2020 | 05:45 PM
1993FXSTS's Avatar
1993FXSTS
Pre-Evo I could understand a worn engine nearing 25%. Harley did have a problem keeping cylinders "round." With modern machining techniques, and today's metallurgy, there is no excuse for 25% leakage. I cannot believe that they meet emissions with numbers like that. Oil burning is a huge hit on exhaust contaminants. Combustion byproducts raise hell on the engine oil too, and mixed with moisture create acid that etches journal surfaces.
Old Dec 19, 2020 | 06:14 PM
TwiZted Biker's Avatar
TwiZted Biker
I do it cold when I'm looking for other issues with an engine, actuall cylinder sealing performance at operating temp and repeat 3 times then average the numbers, it will fluctuate.
Old Dec 19, 2020 | 10:15 PM
Naz's Avatar
Naz
I've seen significant differences from cold to hot and then I've seen smaller variations. The leakdown test is just one data point that should be used in concert with other diagnostic tools when troubleshooting or making condition evaluations. I find the biggest values are as a baseline reading on a new engine and when performing a condition assessment it can instantly indicate where the leakage is at. If you're also performing a compression test, don't forget to adjust for density altitude at the time of the test.
Old Dec 19, 2020 | 10:58 PM
skydude426's Avatar
skydude426
Good information, thanks!
Old Dec 20, 2020 | 05:18 AM
General Hangover
Question
Sorry - I don't understand this. Can you explain a little bit further? Are you talking about the air pressure in the environment in which you're doing the test? For example in the mountains or at the sea?
