No power, help!
Old Feb 26, 2021 | 02:43 PM
zachb1112's Avatar
zachb1112
1st Gear
Default No power, help!
okay so after an accident to the front end of my bike ( 2004 ultra classic ) I decided to rebuild the front end myself. All was going well until I got to final assembly, I had to completely unhook the entire wiring harness inside of the fairing to take the fairing off because I broke the forks and bent my handlebars well now that I put it back together I have no power to the bike at all I've tried 3 batteries now and I either have the worst luck with batteries ( I was buying an amazon brand so its possible I guess ) or theres something else going on. the only thing I get is a slight static noise through the speakers when I hook the battery up that lasts about two seconds maybe.
Old Feb 26, 2021 | 03:56 PM
scooty2321's Avatar
scooty2321
Just shooting from the hip here have you checked all your fuses and relays ?
Old Feb 26, 2021 | 03:59 PM
Max Headflow's Avatar
Max Headflow
Did you remember to plug the harness into the ignition switch?
zachb1112's Avatar
zachb1112
1st Gear
Everything worked when I unhooked the battery to take everything apart so I don't even know where to start as far as that goes was hoping for an idea to narrow it down a little by posting.
Old Feb 26, 2021 | 04:00 PM
zachb1112's Avatar
zachb1112
1st Gear
That was the first one I plugged in because I was worried about forgetting it. lol
Old Feb 26, 2021 | 04:54 PM
whylee's Avatar
whylee
I wouldnt think the speakers would make any noise just from hooking up the battery if the ignition is off. I bet some wires are crossed somewhere.
Old Feb 26, 2021 | 05:01 PM
zachb1112's Avatar
zachb1112
1st Gear
it did this to me before I crashed the bike when I hooked up dead batteries before and always thought it was weird but I didnt question it because everything worked fine now im just confused
Old Feb 26, 2021 | 05:25 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Have the battery load tested (don`t waste your time troubleshooting until you have done this), check all battery cable connection points, clean and secure.
Make sure the main fuse is installed...
Make sure the relays are installed.
Unplug the connector from the ignition switch, with you voltmeter read the voltage at the Red wire, what is the voltage?
Once again....Don`t bother troubleshooting until the battery has been load tested, and is given a clean bill of health...
Old Feb 26, 2021 | 05:35 PM
zachb1112's Avatar
zachb1112
1st Gear
I already got a refund from the amazon batteries I was using, I'm planning on going to harley and getting an oem battery maybe tomorrow to see if that fixes the issue before i tear anything apart. I really wanted ideas because it feels weird that 3 batteries would be dead but it wouldnt surprise me
Old Feb 27, 2021 | 06:31 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
I strongly suspect you’ve crossed two connectors. Two connector sets that fit together, but are of the wrong wires.
were it me, I’d undo the connections, all of them, and redo, paying attention to the wire colors when disassembling and reassembling.
Tree1381
Audio Systems
Apr 3, 2020 05:14 PM
XLRG
Feb 24, 2019 04:47 PM
wlibert
Apr 15, 2012 11:58 AM
Indy Road Dog
Sep 14, 2010 06:40 AM
