Starter problem
Old Jun 8, 2021 | 09:44 PM
Tarheel2288's Avatar
Tarheel2288
4th Gear
Originally Posted by mfortkamp
On the 07 they relays are under the side covers. I don't remember which side. I've had the same problem with mine. A quick way to check the starter is to pull off the small green wire off of the starter and jump it with 12 volts from your battery. Just be sure that you have it in neutral because it bypasses everything and it will take off on you if it is in gear.
thank you!
Old Jun 12, 2021 | 07:51 PM
Tarheel2288
4th Gear
Update, I picked it up from getting bars put on and it started fine. Put a couple hundred miles on her today and she started great all day. Guess I’ll see if it happens again and I’ll know where to start. Thanks for the help.
beefcakex74
Jul 25, 2020 04:22 PM
flht2009
Apr 8, 2014 08:15 AM
michael of North Platte
Shovelhead
May 14, 2012 12:27 PM
bikerlaw
EVO
Aug 9, 2010 12:28 AM
ackmoe
Nov 18, 2005 03:56 PM
