No spark
Old Jul 4, 2021 | 06:07 PM
Wizzard1's Avatar
Wizzard1
1st Gear
Default No spark
had no battery in my 2006 ultra classic all winter.now installed battery whent to start no spark.ive checked cps.it reads 98 ohms.checked fuses all good.fuel pump comes on and pressures up then shuts off .checked codes and no codes found in all area,s.need some advice on direction to go
Old Jul 4, 2021 | 06:09 PM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
Since this is NOT a Forum Issue, I have moved this to the Touring Section. Please make sure you are in the right section before you post your thread or message.
Izzo
Admin
Old Jul 4, 2021 | 06:24 PM
MURPHCC1's Avatar
MURPHCC1
Welcome aboard from Old Cape Cod!
Old Jul 5, 2021 | 12:36 PM
Dseago1969's Avatar
Dseago1969
How did you test for no spark? If it was tested correctly, I would check the coil pack’s resistances.
Old Jul 5, 2021 | 12:41 PM
Wizzard1's Avatar
Wizzard1
1st Gear
I left spark plug in .took extra plug and attached to plug wire and ground on head and cranked engine.what resistance should coil have !
Old Jul 5, 2021 | 06:17 PM
Dseago1969's Avatar
Dseago1969
Should be 3 or 5. Five is a hot coil for racing. Typical s 3. With either if you are out .2 or more it it worth changing.
