Possible Ignition problem??? Help
Old Aug 12, 2021 | 01:54 PM
1Reaper's Avatar
1Reaper
Default Possible Ignition problem??? Help
So bringing my 2018 RG special home for. STURGIS the battery died while in the trailer, seemed weird because it's never done it before. Along the drive my phone told me the Bluetooth on the RG stereo was trying to connect which was also-ran weird because it bike was completely off.. Get home, charge the battery and they bike will light up the gauges while the ignition is in the off position?.? I charge the battery again last night and today it's doing the below video problem...
Help
https://youtu.be/lmvPxp9eI4A
Old Aug 12, 2021 | 01:58 PM
inkdemon's Avatar
inkdemon
Might be battery is shot.
Old Aug 12, 2021 | 01:59 PM
inkdemon's Avatar
inkdemon
First check that wires are tight on the battery as well as on the opposite end of ground.
Old Aug 12, 2021 | 02:01 PM
1Reaper's Avatar
1Reaper
Battery problem was my first thought too but how would it be turning on when the toggle is in the off position???
Old Aug 12, 2021 | 06:40 PM
speedy meadows's Avatar
speedy meadows
it's obviously your bike does not like to be trailered and is upset with you try pulling the main fuse and maybe it will reset it probably should pull the main fuse when ever its trailered good luck hope its that simple
Old Aug 13, 2021 | 09:56 AM
Boomer1143's Avatar
Boomer1143
Did you have your bike in "Transport Mode" while being trailered? If not that would be the reason for the dead battery. The security system would have drained the battery. You might try pulling the main fuse as has been suggested. Hopefully this will help.
2013superglideseattle
Jul 29, 2017 10:05 AM
Tim Woody
Sep 18, 2016 10:35 AM
essentialcycle
Jul 16, 2010 06:52 PM
LebHDMan
May 31, 2010 08:01 PM
clove07
Shovelhead
17
Aug 17, 2009 11:41 PM
