Battery
Old Nov 7, 2021 | 07:15 PM
Jayvee1's Avatar
Jayvee1
6th Gear
Default Battery
Hello gents, just wanted to grt an opinian on purchasing a battery for my 2016 Road Glide, and do I need to disconnect the main fuse in order to avoid and electrical issues?
Thank you all!
Old Nov 7, 2021 | 07:36 PM
kel03's Avatar
kel03
When you remove the battery, always disconnect the negative cable first. (It's usually black, and the corresponding terminal on the battery is normally marked with a “-” sign). If you switch this order, nothing bad will happen — if you don't make contact between the positive side of the circuit and the ground
Old Nov 7, 2021 | 07:41 PM
TriGeezer's Avatar
TriGeezer
1) Turn the ignition on.
2) Pull the main fuse
3) Remove Negative cable from battery
4) Remove positive cable from battery
5) Replace battery
6) Instsll positive cable
7) instsll negative cable
8) Instsll main fuse
9) Turn off ignitiin
10) connect battery tender until fully charged.
Old Nov 7, 2021 | 07:45 PM
nobodyknowsme's Avatar
nobodyknowsme
5) Replace battery
Which is the main fuse for those that need to know?
Old Nov 7, 2021 | 07:48 PM
TriGeezer's Avatar
TriGeezer
Pull the left side cover. In the fuse block it will be the biggest one. Mine is 50A. I clean the contacts and put dielectric grease on it when I reinstall it.
Old Nov 8, 2021 | 09:40 PM
Jayvee1's Avatar
Jayvee1
6th Gear
Default Thank you everyone!
Thank you so much everyone!
Old Nov 8, 2021 | 10:17 PM
Blue Blood's Avatar
Blue Blood
5) Replace battery
What’s the reason for ignition being on when pulling the fuse and why is the fuse being
pulled?
Old Nov 8, 2021 | 10:23 PM
Taxgod4u's Avatar
Taxgod4u
My bet is that the alarm has a battery of its own and will think you are cutting the power and stealing the bike.
Old Nov 9, 2021 | 08:54 AM
Boomer1143's Avatar
Boomer1143
It’s time to replace the battery in your ride. If your bike has a security system on it and you don’t want to listen to the siren while you change your battery here’s what to do.
No Alarm Battery Replacement!
Turn ignition to on (engine not running) with fob near, pull main fuse.
Turn ignition switch off.
Replace battery. Yes, do remove the negative cable first and reinstall it last.
Have fob near, put main fuse back in.
Turn bike on and check that everything is working correctly.
Done.
Old Nov 9, 2021 | 09:53 PM
Jayvee1's Avatar
Jayvee1
6th Gear
Default Tha
Than you, for your advice, will do!
