Here's one for you...! ARGH!
Old Aug 8, 2007 | 11:52 PM
tphillips's Avatar
tphillips
Default Here's one for you...! ARGH!
Had my bike at the dealer (not the one I usually frequent) to have my new touring handlebars put on. One of the cables to be replaced was the clutch cable. In doing that replacement, the tech lost some of the tranny fluid. (I run Red Line -- not Syn3.) He noticed that it wasn't what the shop used, inquired about it, had me pick up a replacement bottle of Red Line, and he was going to top it off. I gave it to him on my way by the shop, and he was going to top off the tranny the next morning.
However, another tech picks up the work order, sees the bottle of Red Line, and assumes that it is to replace the fluid in the primary (what the #$%^????). So he drains the fluid from my primary, puts in Red Line (NOT the proper application), and then I get a call that my bike is ready to come pick up. (Now all of this is revealed to me AFTER I pick up the bike, ride it for about 80 miles, and then call the dealer to remind them I want the rest of my Red Line fluid the next time I'm in the shop.) "What, rest of the fluid?" the tech says... "I put it all in the primary."
WHAT??? Imbocile..... Whatever gave him the idea that it should be changed is beyond me........
Now I'm heading back in there to have them drain the primary, put in Syn3, and top off the tranny with the Red Line as originally intended.
Sooo, here is the question: What is the chance of any permanent harm done to the clutch plates and primary components? The Red Line is a lot slicker than the Syn3 and meant more for gears... I'm thinking I walk in with a pre-typed page recounting what was done by the dealer, have the service manager sign it -- then hope I never need it for a primary/tranny/etc... replacement battle.
Thoughts on this?
Old Aug 9, 2007 | 01:39 AM
GlennsGlide's Avatar
GlennsGlide
Default RE: Here's one for you...! ARGH!
HD is suppose to be the best motorcyle in the world ( that statement in it self is drawing a long bow ) but even if they are the best motorcycle in the world they certainly are not maintained by the best mechanics in the world.
My advice for what is worth is to document including dates, discussions and mistakes made and if posible get something signed. And also notify in writing to the MoCo what has transpired . ( send it by fax, email or registed post ).
I truly hope that no damage has been and Good Luck.
GlennsGlide
Old Aug 9, 2007 | 06:04 AM
kurtlange's Avatar
kurtlange
ORIGINAL: tphillips
why??
if they can't do it right the first time, why trust them to fix it...
do it yourself.
Old Aug 9, 2007 | 06:52 AM
kdietz's Avatar
kdietz
Probably no harm done, but the only way to get the Redline out of there is a complete disassembly and bath....don't let them just try to drain it out and then put in primary fluid
Redline Shockproof can only be totally removed in a solvent tub
Old Aug 9, 2007 | 01:49 PM
mrsr71's Avatar
mrsr71
I'd be calling my lawyer [sm=joke.gif]
Old Aug 9, 2007 | 05:45 PM
Longtimegone's Avatar
Longtimegone
You shouldn't worry so much. The only problem you may have is some clutch slippage. After you change the fluid to a less slippery fluid, whether it is syn3 or redline mtl or hd formula+, the fluids will mix and any slippage will not stick around for long. I might suggest you go with redline mtl or the HD formula+ instead of the syn3.
Old Aug 9, 2007 | 05:55 PM
ndotken's Avatar
ndotken
I think the phrase "Justifiable Homicide" applies here.
bikerlaw
Aug 22, 2024 06:45 PM
m1369x
General Topics/Tech Tips
Feb 25, 2019 08:33 AM
big- mike
May 3, 2017 04:35 AM
Fusionfool
Aug 1, 2014 02:50 AM
tphillips
Aug 26, 2007 08:17 PM
