Heated gear
Old Nov 28, 2021 | 07:38 AM
kazanimo's Avatar
kazanimo
Default Heated gear
Trying to get some information on heated riding gear. I have a electra glide standard. Can I power two full sets of gear (gloves vest and pants) from bike power supply. If I can power both sets would they not heat as well due to powering 6 pieces.
Or should I do a mix of 12v power supply and 7v battery power. For less strain on charging system. Thanks for any information
Old Nov 28, 2021 | 08:03 AM
Ultra103's Avatar
Ultra103
Look at the amperage on the gear you are wanting to run, you have 15 Amps to use. If the combined amperage is less than that you'll be fine. You can also use the charging pigtail on the right side of the bike near the starter for additional gear, if equipped. If not, adding a pigtail is cheap and easy.
Old Nov 28, 2021 | 10:33 AM
bagger67's Avatar
bagger67
6th Gear
Added a 50 amp to my hd and i run two suits no issue 2007 electra glide
Old Nov 28, 2021 | 11:19 AM
Bent and Broken's Avatar
Bent and Broken
Interested to hear from someone who has run two suits. I might be overthinking this but…..
Might have to add up all the draws (lights, radio and two suits) and compare to alternator amperage output. Battery would require a bit more amps when it gets real cold.
Old Nov 28, 2021 | 11:21 AM
bagger67's Avatar
bagger67
6th Gear
What kind of bike the newer touring bikes have a 50 amp alternator.
Old Nov 28, 2021 | 11:31 AM
Bent and Broken
Love this forum, ask question and get an answer
2017 street glide
Amp draws from gerbing
https://www.gerbing.com/battery-harness-installation
Old Nov 28, 2021 | 11:44 AM
bagger67's Avatar
bagger67
6th Gear
I think with that year you will be ok, i use two jacket liners, gloves and socks with no issue
Old Nov 28, 2021 | 11:53 AM
Bent and Broken
Thank you
Old Nov 29, 2021 | 10:52 AM
RKZen's Avatar
RKZen
Pretty sure those amp draws are at max settings. 50% on the jacket liner and gloves and I'm sweating.
T^2
Nov 19, 2017 10:54 PM
dixonk
2014-2024 Touring Models
13
Aug 28, 2015 06:31 AM
CVORoadKing2013
Sep 20, 2012 04:42 PM
mavrickFLHR
Jan 24, 2010 05:51 PM
ford
Mar 15, 2009 08:18 PM
