help please
Old Dec 19, 2021 | 04:24 PM
Samo55's Avatar
Samo55
6th Gear
Default help please
i put a 04 103 screaming eagle,in a 01 road king.everything works perfect exept 04 dont have cam sensor how to bypass.and may i ask the fuel inj has 24 tooth and carb has 25 are they inerchangable if you use the chain and clutch basket with it
Old Dec 19, 2021 | 08:35 PM
Ed Ramberger's Avatar
Ed Ramberger
The cam gear and cover can be changed engine to engine. The gear needs to have a raised portion that the sensor in the cover reads.
If you need the 25 tooth i have several and we could work out a trade or something for the 24 if yours is minty - mine are new take offs.
Old Dec 20, 2021 | 12:59 PM
Samo55's Avatar
Samo55
6th Gear
thanks brother,24 is what i need,can i use 25 if i got chain and basket for it i usely try to figure it out but advise would help thanks man
Old Dec 20, 2021 | 03:26 PM
Ed Ramberger
EFI = 24 Comp 37 Clutch
Carb = 25 Comp 36 Clutch
Interchangeable as a set but you will be happier with the EFI gearing as it is a bit snappier if just running around town. Back then EFI cost more and that gearing made you feel a little pep for what you paid.
Once I built my motor I changed to the Carb gearing as I was doing a lot of highway running. If memory serves me correct it's something like 250-300ish rpm difference.
I have several of the 25 comp gears if you can't find the basket you need.
Here is the gear you need for the cam. If you can’t find one at a decent price pm me. I have several. If you install this and use the original cover with the sensor you’ll be good.
Cam gear for bikes with cam sensor
Old Dec 20, 2021 | 04:16 PM
Samo55's Avatar
Samo55
6th Gear
thanks so much i changed cam gear (factory billet cam plate with hydrolic tent.)cvo and used 88 cover with cam senser wired it up and bam fired rite up.thanks for your help realy
Adam76
Sep 15, 2020 06:39 AM
ffron69
Jun 4, 2015 01:01 AM
laker36
Exhaust System Topics
Jan 20, 2014 08:59 PM
sixpick
Aug 10, 2010 06:57 PM
johntheone
EVO
22
Apr 15, 2008 02:10 PM
