I have a 2016 Tri-Glide ultra. I listen to music on a UBS dive most of the time. I was in the mood for a certain song yesterday, so I used the voice feature to have it play that song. Worked fine. Now that song is all that will play. I can request any other song, and then the new song plays over and over again. How do I get back to the random shuffle of the drive?
start from the beginning. select your audio source, in this case usb. then you have options for artist, song, etc. select 'all songs', and make sure 'shuffle' is checked. been a while since i've done this, so going from memory. but should get you there.
Did that for 10 minutes. When I plugged it back in, it started right where it left off.....LMAO
If the radio is set to play different songs then pull your main 50amp fuse located under the left side side cover and leave it out for 30 to 45 minutes, the longer the better, you need to have the radio discharge all capacitors, or you can remove your seat and disconnect the positive battery cable, you will want to remove the 50 amp fuse before you do this. When I had this happen to me i had to reset the whole bike. I then updated the firmware on the radio,
is there a repeat option on your playlist and is it enabled?
