Brake lights
Old Jun 2, 2022 | 03:26 AM
Longpockets's Avatar
Longpockets
Default Brake lights
I have a 2004 road king and my brake light are not working but running lights are I checked the fuses and they are good can anyone give me and idea of what it can be? Thank you
Old Jun 2, 2022 | 04:33 AM
Jackie Paper's Avatar
Jackie Paper
Neither the lever or pedal make them work? If that's true, it narrows it down to wiring from seat back to bulbs starting at relay.
Now it also depends on how long you ignored say the brake pedal not working and lever working. If that's the case, then it could be the lever switch and the hydraulic pedal switch.
I have replaced the lever switch once and the hydraulic one 3 times. That one I gave up on Harley and got a Lifetime AutoZone one for a 55 Chevy.
PS . Note that a Softail does not appear to have a brake light relay I don't think. If it does, not sure where it is. I don't have access to wiring diagrams on my phone.
Old Jun 2, 2022 | 04:35 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Wiring diagram here - 99949-04_en - 2004 Wiring Diagrams | Harley-Davidson SIP
You can see that the brake switches operate the brake relay. I would start by checking the operation of that relay if neither brake operation works the light.
Old Jun 2, 2022 | 06:28 AM
Longpockets
when I get off work I will start under the seat
Old Jun 2, 2022 | 07:54 AM
chopper_man's Avatar
chopper_man
Before digging in to the wiring start with the bulb. It is a dual element bulb, and the brake side could simply be burnt out.
Old Jun 2, 2022 | 07:56 AM
Longpockets
bulbs are new Led bulbs
Old Jun 2, 2022 | 08:04 AM
NorthWestern's Avatar
NorthWestern
You buried the lead. Was this happening before you put these new LEDs in??
Old Jun 2, 2022 | 08:09 AM
702's Avatar
702
Are they 1156 or 1157 style?
Old Jun 2, 2022 | 08:10 AM
chopper_man
Doesn't mean it's good! Always start at the bulb.
Old Jun 2, 2022 | 08:12 AM
Longpockets
no but I had the leds on for a while!!
what I did lately was change handle bars
