Help! Codes!
Old Jun 16, 2022 | 06:57 PM
TexasSasquatch's Avatar
TexasSasquatch
Default Help! Codes!
I’m on a multi day road trip and my 2020 FLHP just threw a code. I tried to reset it and it re-throws it.
C0077c
I checked online and it said low tire pressure. Front tire pressure is right around 40 and rear is 41. The dash is reading the tpms sensors correctly even when I manually check the tire pressure. I just took it up the street to get gas (before it threw the code) and when getting gas a bunch spewed out onto the tank so I’m thinking maybe it fried something??? I don’t know. I was planning on doing another 200+ miles tomorrow and 350+ the day after that.
I have tried to reset. No luck. I let out about 5 or more psi, rode around the neighborhood, stopped and refilled and rode again, no luck.
Old Jun 16, 2022 | 09:16 PM
NODYNA's Avatar
NODYNA
If it's a code for low tire pressure and the bike reads the correct pressure when you scroll through the screens I would not let that stop my trip.
You could try a reset pulling the main fuse for 5 minutes.
Old Jun 16, 2022 | 10:13 PM
rideonva's Avatar
rideonva
If 41 is on hot tire then it does look a little low. My owner manual states 40 at 68 F when not ridden recently, add 5 psi if recently ridden. Mine didn’t throw codes but prompted to look for gas station and was showing low when my rear was 42 while riding on an 80 degrees day.
2015 Harley Davidson Street Bob Guy
May 26, 2015 12:55 PM
cpiad
Jul 26, 2010 03:41 AM
mentor70
Wheels/Tires
Jun 13, 2010 06:04 PM
morrishuckeba
Feb 23, 2009 05:49 AM
BTL
Jul 20, 2008 12:22 PM
