reverse gear
Old Apr 20, 2023 | 02:34 PM
sparky277480's Avatar
sparky277480
Default reverse gear
I am just checking in to hear from anyone who has the Motor Trike reverse kit installed on their 6 speed street glide. My question is about the exhaust and passenger foot peg. I am currently running a Bassani B4 2 into 1 exhaust and it seems as if will have to be replaced as it will be in the way of the reverse shifter. I need another 2 into 1 system because my saddle bags are made for a 2 into 1. I am just wondering if anyone knows of a pipe that will work and not interfere with the reverse shift lever but also lets the passenger peg function as normal. I know most everyone does not have this reverse kit but im hoping to stumble on someone that does. Thanks for reading
Old Apr 21, 2023 | 12:13 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Are you sure it’s hopeless?
My 04 required some fiddling with the one exhaust mount under the transmission cover, and some fiddling with the exhaust, but it all did fit.
Old Apr 21, 2023 | 07:08 AM
sparky277480
thanks foxtrapper but the reverse shift lever is at the back of the side cover on a six speed transmission (yours is at the front) plus you didn't say which exhaust you have as it all makes a matters.
Im pretty sure a V&H pro pipe will give me the clearance I would need.
Old May 12, 2023 | 06:32 AM
skydude426's Avatar
skydude426
What did you end up going with?
harley#1
Nov 7, 2022 02:03 PM
IG4468
Mar 17, 2014 03:31 PM
thirstybob
2014-2024 Touring Models
Feb 28, 2014 09:29 AM
DoADeuce
Jun 29, 2013 05:31 AM
vharrig
Jun 9, 2006 07:15 PM
