Screen Protectors
Old May 18, 2023 | 11:58 AM
kappel15's Avatar
kappel15
1st Gear
Default Screen Protectors
I purchased a 2017 Streetglide Special. All was good. Then the screen protector got damaged two years ago. Dealer installed a new one, and i can't see the screen now as new protector must be polarized, as are my sunglasses. Has anyone else run into this isssue, and have you found a fix for this issue?. Thanks in advance. kap
Old May 18, 2023 | 12:25 PM
Black Ultra's Avatar
Black Ultra
I also wear polarized glasses, prescription sunglasses. I have not seen a bike screen I couldn't read with them on. I saw dozens when bike shopping. So you can see the screen without your sunglasses and you can see the screen on other bikes with your sunglasses on? If so, replace the screen protector and get one you can see through with your glasses on.
Old May 18, 2023 | 04:38 PM
ridingout's Avatar
ridingout
Did they remove the protective film ?
Old May 18, 2023 | 08:26 PM
kappel15's Avatar
kappel15
1st Gear
As far as i know, they only removed the screen protector. Didn't know there was a "protective" film ? Went for a ride today without a screen protector on. Could see screen a little better, but still dark. Starting to wonder if screen itself is going. kap
Old May 18, 2023 | 08:27 PM
Toypuller's Avatar
Toypuller
I didn’t even know there was a screen protector, until I bought a used 2017 SGS. Was washing it one day, and saw the bubbles.
I tried one aftermarket that just didn’t fit right. Then, bit the bullet, and bought the Harley kit. Comes with 2 screen savers, but the Harley one went on easy, fit perfectly, and has been a non issue since. 2 years later, the other is sitting on the shelf.
Never had an issue with polarized glasses, maybe try a new screen saver.
Old May 18, 2023 | 09:16 PM
kappel15's Avatar
kappel15
1st Gear
I did replace it, but had same result. Road today without screen saver in and could see a little better, but still dark. Starting to think screen itself is going. kap
Old May 18, 2023 | 10:49 PM
bowelder's Avatar
bowelder
Have you tried to adjust the screen brightness?
Old May 21, 2023 | 06:12 PM
Jackie Paper's Avatar
Jackie Paper
Kap, Can't help you on your question but would like to give a shout-out to say....Welcome, hope you enjoy your ride here.
Only as a suggestion, create a signature line for
your bike, year, model, and all the code letters.
And only as a suggestion, make your next new post over in the new member welcome area to say hello...
jeffv1
Pan America
Mar 17, 2022 03:46 PM
702
Milwaukee Eight (M8)
22
Apr 16, 2020 08:50 AM
shred1
Jul 2, 2016 02:05 PM
av ultra
Feb 28, 2013 10:33 PM
jandlcars
Nov 7, 2007 12:23 AM
