Primary Oil Level; small change, big difference
Old May 27, 2023 | 06:58 PM
  #31
gonemad's Avatar
gonemad
Originally Posted by RG Pilot
That’s right. You can even pull the clutch in, blip the throttle and that breaks the clutch friction. Then it’ll go into 1st also without the clunk.
Interesting. I’ll try this.
Old May 27, 2023 | 08:26 PM
  #32
xcbullet's Avatar
xcbullet
Seen this guy today couldn't get it in gear the first try, so then he really hammers on it with the big clunk. Mine always goes right in , I set at the light when the light turns and click it in. Takes me longer to left my leg than it does to get it in gear.
Like has been mentioned one pic is straight up and the other is on the side stand which is just strange as it would run out the screw hole.
Old May 28, 2023 | 08:17 AM
  #33
Weeboy1's Avatar
Weeboy1
Originally Posted by KDF72
Oddly enough I found this true on my 09 EG. I changed the primary using a full quart of Redline primary. I started having trouble finding neutral and my local wrench cautioned about overfilling. For my bike about 27-28 oz works well.
Interesting, What does your wrench consider overfilling? As yours is supposed to take 38oz. If you’re putting 10 oz less (28oz) where is that lining up to on the clutch basket. Not saying what you’re doing doesn’t work for you but that’s a significant reduction.
im curious.
hardheaded
Sep 13, 2022 06:41 AM
Randy Fat Boy
Sep 10, 2021 11:35 AM
Quik
Milwaukee Eight (M8)
69
Jun 26, 2021 08:28 PM
Retrop
Sep 3, 2013 09:50 AM
P51Driver
May 19, 2013 09:23 PM
