2015 CVO temp light, tried everything
Old May 24, 2023 | 08:16 PM
trailbossjr's Avatar
trailbossjr
1st Gear
Default 2015 CVO temp light, tried everything
IM STUMPED
What's up everyone, new to the group .i was always able to find answers to my questions here but haven't found a fix solution for this problem...So i have a 2015 street glide CVO i have a thundermax tuner and a 2 into 1 d&d exhaust.. bike has 17000 miles and last fall temp light came on and then eng light. So i came here to search for all your expertise. I know there are many threads about these 2014 to 2016 water/cooling pumps being a issue, So engine code is p1019 ..So I bought the newer cooling/water pump and installed (fairly easy job) took for a test ride and 10 to 15 min into ride lights came back on..So went to dealer and bought both sensors ,cooling sensor and eng temp senor , installed both sensors .I took it for another test ride and same thing ,both temp and eng light..So what i noticed is the fans are not coming on when im riding or at a idle (even for 10 min) So i tested the fans with engine off and ignition on and holding throttle open for a few seconds and fans will turn on,but wont come on when while riding. I checked fuses. I swapped relays, i checked all plug connectors. I purged system again and took for another test ride and same results ,temp and engine light and no fans ....i only have fans when i do manually...Please Please Please help
Old May 24, 2023 | 08:19 PM
trailbossjr
1st Gear
sorry fans not coming on
Old May 25, 2023 | 02:43 AM
kojak's Avatar
kojak
Originally Posted by trailbossjr
IM STUMPED
PART NUMBER TOOL NAME
HD-41404 HARNESS CONNECTOR TEST KIT
Table 6-64. DTC P1019 Diagnostic Faults
POSSIBLE CAUSES
ECT sensor malfunction
Short to ground in ECT signal circuit
No air flow through radiators
Low or no coolant in system
Old May 25, 2023 | 02:58 AM
MTBIG G's Avatar
MTBIG G
When you did the manual test, did you validate that your pump is ok?
https://www.hdforums.com/forum/2014-...s-working.html
Old May 25, 2023 | 09:46 AM
trailbossjr
1st Gear
I can feel barley feel a slight vibration with hand on pump when i manually turn fans on, its the newer m 8 pump and i guess its really quiet , i was also able to purge the system so im assuming fans are working. I also felt both hoses after a short ride and both are hot (if that means anything) i will say sometimes when reading the codes the ECM says disabled
I have a trip planned june 1st with my buddies to upstate New York Americade , im starting to panic I would gladly pay someone to fix but i called all local dealers and no one can even think about looking at it til mid July ....Please im counting on someone here to save my trip
Old May 25, 2023 | 09:59 AM
chopper_man's Avatar
chopper_man
Not sure where you are in MA, but try A&B Cycles in Sutton. Give Adam a call. He's also a Thundermax master shop.
https://www.yellowpages.com/sutton-m...ycle-481300034
Old May 25, 2023 | 10:25 AM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Since you have a ThunderMax ECM installed I would contact them for proper test procedures as it may be different than the normal HD way. The ECM controls when and how the fans operate so your best answers would come from ThunderMax.
Old May 27, 2023 | 12:21 PM
trailbossjr
1st Gear
updated info, i found a local shop that is a certified thundermax tuner. so he lowered the temp to 160 degrees for my fans to turn on from stock 220 degree. He was able to see the temp history and told me my bike is not overheating. He emailed thundermax to ask about a possible solution to temp light coming on and throwing a po1019 code ( heat difference ).. with the holiday weekend probably won't get a answer till next week. he also checked all the ground connections on bike but still have light coming on.
Old May 28, 2023 | 03:41 PM
Ultra103's Avatar
Ultra103
Hey, you got it figured out. Now that you know it's not overheating, you can enjoy your trip even if the light thing isn't figured out yet.
M@rkus
2014-2024 Touring Models
Jul 25, 2019 05:57 PM
barney5
Jul 3, 2018 11:21 AM
BlackMarshmallow
62
Jul 23, 2016 11:13 PM
jimski
Aug 20, 2010 06:29 AM
praltima
May 17, 2010 11:53 AM
