Cush Drive
Old Aug 11, 2023 | 08:01 AM
dynoking's Avatar
dynoking
Default Cush Drive
Good morning everyone,
I want to up grade my 2007 FLHRES3 to Cush drive. The kit from the MOCO has been discontinued. The 66 T rear sprocket is Japan export only and not available. Can anyone suggest alternatives?
Thank you.
Old Aug 11, 2023 | 06:24 PM
dawg's Avatar
dawg
It may be available still at a dealer that has one in stock and laying around. An employee can do an h-dnet search to see who may have one.
Old Aug 12, 2023 | 07:08 AM
dynoking's Avatar
dynoking
Thanks Dawg, I'll give that a try.
Old Aug 14, 2023 | 05:54 PM
multihdrdr's Avatar
multihdrdr
Did you locate one yet?
I may have one, it would be a 66T
Old Aug 14, 2023 | 09:37 PM
dynoking's Avatar
dynoking
Yes I did, found one on E Bay. Complete assembly with a claimed 7 miles on it. I guess it was a take off. I'm embarrassed (and pissed) to say what I paid for it. Thanks for your follow up and everyone's else's responses.
Old Aug 14, 2023 | 09:45 PM
Harley_ish's Avatar
Harley_ish
Did it have all the parts? Have you checked it to make sure it's for a 1" axle not the 25mm?
Old Aug 15, 2023 | 08:18 AM
dynoking's Avatar
dynoking
It has bearings, no spacers. I didn't know about the two different axle sizes so I didn't ask. This is the link to the EBay posting. The seller states 2008 Touring only. Does that help?
Old Aug 15, 2023 | 08:41 AM
Harley_ish's Avatar
Harley_ish
I don't see a link in your post (that should answer some questions).
You need the setup with a different bearing and spacer(s) for your 2007 1" axle. 2008 used a 25mm.
Old Aug 15, 2023 | 08:47 AM
dynoking's Avatar
dynoking
...with my apologies, https://www.ebay.com/itm/145238783616
Should I buy bearings, spacers, cams, axle nuts, e clip, and an axle for a 2008 RK?
Old Aug 15, 2023 | 09:16 AM
Harley_ish's Avatar
Harley_ish
It appears (at this point) to be 25mm. When you receive it, we'll know for sure.
Come back when you get it.
No judgement, but why did you pick that one (in reference to fitment)? Nothing in the listing says it's for a 2007. In fact he says "2008 only" (the difference being a bearing and spacer(s) change)
