Changing bars
Old Jan 16, 2024 | 01:16 PM
Digger1930's Avatar
Digger1930
Default Changing bars
Hi all,
Looking for a bit of help, I'm looking at swapping out my bars on my 07 SG and can't seem to find the proper info.
Going from stock bars to KST Patriot 10", do I need to change any cables? or do I just need to reroute some stuff?
Old Jan 16, 2024 | 01:25 PM
touchdown's Avatar
touchdown
Most Likely not if your going with 10" any higher yes.
Old Jan 16, 2024 | 04:58 PM
07UltraGuy's Avatar
07UltraGuy
Are you planning to run the cables inside the new bars or externally?
If internal, you may have really short harnesses for them once pulled through.
You can reroute your brake, clutch, and throttle cables to cover the 2” increase, but it will be tight. If your routing isn’t right, you’ll pull on the throttle cables at full lock to the left ( think U-turns).
Old Jan 16, 2024 | 05:59 PM
memphisharley's Avatar
memphisharley
on my 12 I went with 10" yaffees which measures closer to 12". I did change the clutch cable to +6 as +4 was still too tight for my liking. no issues with brake line.
Old Jan 16, 2024 | 06:42 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
I always understood that on the pre-Rushmore’s that HD did not give any extra lengths to work with and you have to change the cables.
I suggest you reach out to Hill Country Customs. They will have all the details and everything needed to do the job right.
https://hillcountrycustomcycles.com/
Old Jan 16, 2024 | 07:12 PM
r8r_4_life's Avatar
r8r_4_life
Only way to really know is to soft install the bars and go from there.
On my ‘09 I went with 12‘s and changed clutch and brake.
Same with my ‘10, but I went with 14’s this time.
Old Jan 16, 2024 | 08:10 PM
NorthWestern's Avatar
NorthWestern
This. Right here.
If you go full internal, get some harness extensions from KST.
I got brain freeze from reading too many bar install threads here, and convinced myself I did not need them with 10 inchers.
I was wrong. I did full internal wiring with heated grips, and came up short on the harness.
Old Jan 17, 2024 | 07:47 AM
Architect's Avatar
Architect
Call KST, decent guys and they will walk you through the process.
KST Kustom Handlebars | Made in the USA – KST Kustoms
Installed a set of pre-wired 12" bars on a 2021 Road Glide, couldn't be easier. Good luck.
Old Jan 25, 2024 | 12:20 PM
Digger1930's Avatar
Digger1930
Thanks all,
Good thing its winter and I have the time to work on it. I'll dry fit the bars and get the parts as need.
Old Jan 25, 2024 | 05:06 PM
julesdain's Avatar
julesdain
Veteran: Canadian Forces
This was the video that I used when I swapped out my bars on my 20 FLHTK although I see you're doing an 07. You may find some answers that you are looking for. I did not need to change any lines but simply did a little rerouting. Good luck.
