Engine light
Old Feb 27, 2024 | 05:22 PM
Harleyuc97's Avatar
Harleyuc97
Default Engine light
97 EGUC
Engine light comes on and goes off. Voltmeter drops to about 10 volts at idle and climbs to about 14 volts at higher rpm’s. Voltage regulator? Bike has just under 70k miles.
Old Feb 27, 2024 | 05:57 PM
memphisharley's Avatar
memphisharley
first check battery voltage at idle and under load and report your findings.
also check for codes its probably one stored.
Old Feb 27, 2024 | 06:33 PM
dawg's Avatar
dawg
With a 97 one can’t check diagnostic codes unless they have the appropriate test light breakout box. I would do a full charging system check.
Old Feb 27, 2024 | 06:54 PM
Harleyuc97's Avatar
Harleyuc97
May sound like a dumb question, but is there a way to read codes on a ‘97?
At idle the voltage is around 10 volts. At hiway speed it climbs a bit over 14 volts.
Old Feb 27, 2024 | 07:13 PM
memphisharley
noted. what about the op checking battery voltage.
thanks
Old Feb 27, 2024 | 09:13 PM
Dano523's Avatar
Dano523
Old Feb 27, 2024 | 09:18 PM
Dano523's Avatar
Dano523
To add, normal for the oil light to be on when you first start the bike, and should go off in about a half second once the motor pressure comes up.
If code is stored, then when you start the bike, instead of oil light going off right way, will stay on for about 10 seconds more before going off.
And being an Evo, motor idle needs to be set at 1K RPM's, or your going to have oil pressure problems to being with the motor idling lower than that, as well as low charging voltages as idle as well.
Old Feb 27, 2024 | 10:03 PM
Harleyuc97's Avatar
Harleyuc97
The light doesn’t come on at idle, it comes on around 40-50 mph. It goes off as the rpm’s come down. Also the voltage swings from around 10 volts up to 14 volts as rpm’s increase and drops to 10 volts at idle. I haven’t noticed this swing in voltage previously.
Old Feb 28, 2024 | 03:22 AM
YZR's Avatar
YZR
Bad voltage regulator?
Old Feb 28, 2024 | 04:09 AM
Jackie Paper's Avatar
Jackie Paper
Assuming battery shows good and cables are good, corrosion free and tight.
Check the stator first. For grounds. For AC voltage. You've already told us what the regulator is doing.
It just may be doing the best it can if stator is bad or battery is bad too
Stator is easy check with a volt/ohm meter.
How to in the sticky.
