2000 flhtpi backfire.
Old Jul 23, 2024 | 11:22 AM
Gunny69's Avatar
Gunny69
Stage I
Default 2000 flhtpi backfire.
Hello,
I am new to this forum and could use some help.
I just purchased a 2000 police bike with 62000 miles on it. It has a random backfire that is slowly getting worse. The only time the backfire is consistent is at 1300rpm. It has the magneti marelli injection system. Where should I start looking to fix this ?
Thanks in advance.
Old Jul 23, 2024 | 12:17 PM
svarnster's Avatar
svarnster
sounds lean. what mods have been done. exhaust, cams ....... does it have a tuner or has it been tuned. All of that and much more could be involved.
Old Jul 23, 2024 | 12:26 PM
Ultra103's Avatar
Ultra103
Check your exhaust flange tightness at the heads. Check for a cracked exhaust pipe close to the rear head.
Old Jul 23, 2024 | 01:16 PM
springers4ever's Avatar
springers4ever
Cool Link...
you need to watch and perform this and see if this helps...
this will work on the EVO and Twin Cam
Old Jul 23, 2024 | 01:37 PM
internet troll's Avatar
internet troll
THIS ^ . Exhaust leaks from broken or loose manifolds are very common and most often manifest themselves in lower rpm popping. Dont forget to check your Y pipe or any other kind of crossover.
Old Jul 24, 2024 | 12:38 PM
Dano523's Avatar
Dano523
https://www.youtube.com/watch?v=bY6Pw8WpSfc
Nope on the postion sensor, since 2000 twin cam throttle body position sensor is not adjustable like the earlier MM slotted evo sensors.
My guess, would be either intake or exhaust leak (or motor just running too lean), and since was until later that they did way with the crank sensor on the twin cam motors, may be a problem with crank sensor starting to go out as well. I TB throttle posistion does have a flat spot, then way to pull it apart to clean and solve that problem.
As for other items that come to mind, when was the last time the fuel filter in the tank was replace, other parts checked for a leaks in tank as well, since these could be causing the motor to run lean as well.
Artlee
Motorcycles For Sale
Apr 7, 2014 12:24 PM
runningbearau
Jul 12, 2013 02:47 AM
Bdobb
Jun 2, 2011 08:55 PM
2WheelsNow
May 12, 2009 04:08 PM
sportsterxl50
All Other Models
Jul 14, 2008 03:07 PM
