Question about Thunder Max
Old Sep 4, 2007 | 02:18 PM
shortleg's Avatar
shortleg
Default Question about Thunder Max
I have installed my Thunder Max and downloaded my base map.
My question is how long for it to learn and stop the pop I have
on decel.It,s not bad but it is there.
Thanks
Shortleg[Dave]
Old Sep 4, 2007 | 02:23 PM
Akitakoi's Avatar
Akitakoi
Default RE: Question about Thunder Max
I've had the Pop since I installed it. I heard about some software coming out to fix it soon.
To be honest the bike runsSO GOOD! The pop just does notbother me.
Took a couple tank fulls for my milage go from around 30 to close to 40, the butt dyno was happy from the first mile.
What map # are you using?
Someone in the know will chim in soon.
Old Sep 4, 2007 | 03:23 PM
kdietz's Avatar
kdietz
If your map matches your components...or are very close...give it 200-300 miles before making adjustments....it just keeps getting better and better
Old Sep 4, 2007 | 03:32 PM
mps1168's Avatar
mps1168
GOD I can't wait until I can afford my own T-Max. So many good reports on that thing.
mps
Old Sep 4, 2007 | 03:48 PM
stro1965's Avatar
stro1965
Zippers e-mailed me the firmware update but I can't figure out to get from e-mail attachment to my module. Anyone?
Old Sep 4, 2007 | 03:58 PM
Akitakoi's Avatar
Akitakoi
ORIGINAL: stro1965
I have a copy of it too, says to put it in the updates folder???
I figure I'llwait and watch for the final release with the FULLinstructions.
Old Sep 4, 2007 | 04:25 PM
Plow64's Avatar
Plow64
Save the e-mail attachment toa laptopthat has the Smartlink software installed on it.Then plug the laptop intothe module, make sure you've got a good link,and use theSmartlink IVsoftware to update themodule's firmware. This can be done by clicking on the "Configure"drop down window to select "Firmware", thenclick on "updgrade module firmware now". From there you should be able to import the attached file that's on your laptop and load it into the EFI Controller. Should work.
Old Sep 4, 2007 | 05:19 PM
cardboard's Avatar
cardboard
If I remember right there are like 1800 squares that yer computer can build information in with the auto tune. Hope you plugged the auto tune cable into the auto tune part. Hope you checked the closed loop part too under configure. If you update yer software and update yer firmware and hook the bike to yer notebook and if I remember right it ask's for you to turn yer switch on and it updates itself. Call Zippers and ask, YOu can download the manuals online at www.thunder-max.com and print them out. If I don't do something often I tend to have to forgit how I did it. But I like the dawg out of my Tm A/T
Yer bike tunes at all parameters according to how you drive. If you drive slow, it will only tune at those rpms. It follows the RPM's and the throttle posititon sensor. When you wind the rpms up higher it will tune for that part. Just take yer time and let it do its thing then later on take it out and hammer it on the interstate and wind it to the rev limiter.
koolbreez
The Dyno Room
Feb 18, 2019 10:44 AM
PEESKI
Oct 8, 2017 01:35 PM
keno
Apr 23, 2014 04:59 PM
pmcburne
Sep 30, 2009 01:34 PM
Spike_96
15
Aug 9, 2008 09:36 AM
