Engine oil
Old Sep 8, 2007 | 11:52 AM
Gusrk's Avatar
Gusrk
Stage II
Default Engine oil
Hello Folks,
I ride a '05 RoadKing all year long, live in Colorado.
I ride from 15 deg F to 100+ degF, what engine oil
do you reccomend?
I'm currently using HD 20W 50.
Thanks, Gus
Old Sep 8, 2007 | 11:58 AM
WildBill2566's Avatar
WildBill2566
Default RE: Engine oil
Hi Gus,
Check out the oil section, loads of views on oil. 20W50 fully synthetic Amsoil, Redline or Mobile will be just fine for the engine. Gear oil in the gears, MTL in the primary.
WB
Old Sep 8, 2007 | 12:00 PM
Cache's Avatar
Cache
Amsoil 20W50 I use. Works very well for me.
JMHO
Old Sep 8, 2007 | 12:01 PM
Bryan TTM's Avatar
Bryan TTM
nice first post
Old Sep 8, 2007 | 12:11 PM
UltraKla$$ic's Avatar
UltraKla$$ic
Peanut oil
0% trans fat
keeps my bike lean and mean.
Old Sep 8, 2007 | 01:13 PM
glide's Avatar
glide
20/50 would work fine. Any sustained riding in 100* temps would probably be better off with 20/60 for a bit more protection. Some even use straight 50Wt in hot temps.
Old Sep 8, 2007 | 04:32 PM
Gusrk's Avatar
Gusrk
Stage II
Thanks for the input: allot of people are using Amsoil these days.
Gus
Old Sep 8, 2007 | 04:46 PM
Roofuss96's Avatar
Roofuss96
Redline --all 3 holes
Old Sep 8, 2007 | 04:57 PM
drdiesel1's Avatar
drdiesel1
Mobil 1... 15 -W- 50
Old Sep 9, 2007 | 04:25 AM
PapaTravis's Avatar
PapaTravis
Amsoil 20w-50 in engine, Amsoil 75w-90 in the transmission, and either Amsoil 20w-50 or HD Formula + in the primary. You really don't need to spend the money for synthetic for the primary, the formula + is just fine. I started off with the Amsoil in the primary, but had a small leak at the drain plug, when I removed the plug to fix it, I had to add the formula +, since my Amsoil guy was closed and HD was open. I am sure either will be fine. Good luck, and don't be afraid to ask any question you may have. never a dumb question, but you might get some smart @ss replies. LOL Also, check out the search feature, as this might help you find answers to your questions. And don't forget to figure out how to post pics of your ride. We all love to see them.
