What size Ohlins rear shocks, 779 or 778?
Taller wheels use low profile tires with stiffer sidewalls because something still has to support the weight of the machine. It's the combination of stiff sidewall low profile tires and a larger front wheel which makes for a rock hard ride.......I'm not sure if shocks will make much of a significant change in the ride.
Might have to "bite the bullet" and change out the tires & wheels. Too bad you can't take a ride on one that isn't set up with such a large wheel and stock shocks for comparison.
joelsuff
Apr 1, 2015 04:50 PM
ClassicRider99
Aug 26, 2014 12:05 PM
