lost running lights
Old Oct 1, 2007 | 05:37 AM
ricaroo's Avatar
ricaroo
Default lost running lights
Went riding yesterday, I got home just after dark and noticed that my running lights were out. The brake and directional worked fine. I checked out the fuses and found the one for the lighting was no good. I replaced it and everything is working again. does anyone have any idea what would cause the fuse to blow? I did not wash the bike and didn't ride in any rain.
Thanks
Rick
Old Oct 1, 2007 | 05:45 AM
dawg's Avatar
dawg
Default RE: lost running lights
I don't see a ride bell on your scoot in your pics....I'd say it was them pesky road gremlins. Or it could be that you went against all advice here on the forum and chose some off the wall brand of oil
Old Oct 1, 2007 | 06:21 AM
SubZer0's Avatar
SubZer0
Better get one of those IDS thinga mabobs. I hear if cures what ever'swrong with your bike.
Old Oct 1, 2007 | 07:23 AM
choochoo's Avatar
choochoo
Could be just one of those things.
But if it does it again, check inside the light for any moisture etc.
Also check the rear harness wiring under the rear fender for a rubbed
bare wire.
Would be the most likely place to look.
Assuming when you say running lights you are talking about the tail lights on the bike.
Old Oct 1, 2007 | 08:13 AM
stimul8ing guy's Avatar
stimul8ing guy
i just had this problem with my 05 UC. check to see if theamber running light on the front fender is on, secondly check the wiring under the front fender for exposure...that's where my prob was, i pulled the wire just behind the left side front fork and found the wire was rubbed bare and every time it touched the fender it blew the fuse...good luck!
Old Oct 1, 2007 | 08:22 AM
racklefratz's Avatar
racklefratz
When I got my bike back from dealer service, I found the lead from the front fender light misrouted on the front side of the forks into the batwing, and it got pinched there and wore through the insulation, causing a short. The fuse that blew took out the tail light, the tour pack lights, and the front fender light.
Old Oct 1, 2007 | 08:57 AM
Akitakoi's Avatar
Akitakoi
Check the Fuse.
Mine blow for no reason very so often. Under the Left side cover.
Old Oct 1, 2007 | 09:09 AM
NCCopBikeRider's Avatar
NCCopBikeRider
JB Weld will solve the problem
Old Oct 1, 2007 | 06:31 PM
ricaroo's Avatar
ricaroo
I did check the fuse and it was blown, I changed it and everything seems ok. I guess time will tell. Thanks for all the good advice
Dagda889
Feb 14, 2017 12:14 PM
banditgrrr
Electrical/Lighting/Alarm
Oct 31, 2014 06:44 PM
QuasiDemon
Apr 24, 2011 04:11 AM
dub976
Aug 30, 2010 05:55 PM
ESS9
May 31, 2007 10:25 PM
