Code???
Old Oct 15, 2007 | 08:15 PM
hennyk's Avatar
hennyk
Default Code???
I was washing my 07EGC this evening and the mileage odometer lit up and had some kind of code on it. Something like dAl 9. What the heck was that? Anybody else have this happen.
Old Oct 15, 2007 | 09:26 PM
pkenyon1's Avatar
pkenyon1
Default RE: Code???
It was trying to say...
DIal 911...
But died on you before it got the whole message out!
Old Oct 15, 2007 | 09:43 PM
Biggzed's Avatar
Biggzed
Default RE: Code???
That code (or part of a code) does not appear on the list of '07 Trouble codes I have. If you want the pdf of all the codes, send me a PM with your e-mail address and I will send it to you.
Old Oct 15, 2007 | 09:44 PM
voodoodrug's Avatar
voodoodrug
Default RE: Code???
thumbed thru e sm and did not see any dtc close to that. if it happens again write it down. Thanks for given me an excuse to look in the elect manuel. good luck
Old Oct 16, 2007 | 01:42 PM
twincam47's Avatar
twincam47
Default RE: Code???
it said "diag"
hold your odo button in a turn the ignition on with run switch onand you will see the same thing..
you will also see your speedo sweep and all the lights in the speedo light up.
It is going through a diagnostics test. The "DIAG" is in goofy letters like some in upper and lower case.
See page 2-12 of the 2007 Electrical Diagnostics manual for complete instructions of the diagnostics system and code retreival.
water or something must have gotten to it.....
Old Oct 16, 2007 | 04:05 PM
texan321's Avatar
texan321
Default RE: Code???
ORIGINAL: pkenyon1
DIal 911...
Ok I needed that today - that was funny!!!! Why would you put water on a bike???
IronMan69
Apr 7, 2019 01:22 PM
heavymetalthunder
May 5, 2018 11:02 AM
usaztec66
Apr 26, 2015 02:21 PM
pat.h
Sep 6, 2014 06:05 PM
HDF Tech
General Topics/Tech Tips
Jul 21, 2005 10:41 AM
