OIL
Old Oct 23, 2007 | 06:00 PM
mhuckeba's Avatar
mhuckeba
Default OIL
I was told by the AMSOIL man that could put 20 W 50 in all 3 holes on my 2007 Ultra. What do you think?
HUCK
Old Oct 23, 2007 | 06:06 PM
scofield333's Avatar
scofield333
Default RE: OIL
You could but I wouldn't...I use AMSOIL 20W50 in the Motor, 75W140 gear oil in theTranny and H-D Formula + in the primary...3 different enviroments. Do so research on this forum and you well see alot of things concerning this
Good Luck
Old Oct 23, 2007 | 06:10 PM
Plow64's Avatar
Plow64
Default RE: OIL
Have heard that also, but think you're better servedusing Amsoil Severe Gear for the tranny, especially with an '07. It'll smooth out the tranny better than the 20W50.
Old Oct 23, 2007 | 07:12 PM
jag1886's Avatar
jag1886
Default RE: OIL
20w50 in the engine and primary and 75-110 Severe Gear in the transmission. The heavier lube in the transmission makes it way quieter. If you look at the AMSOIL web sight they recommend75-110 first and 20w50 second in the transmission.
Old Oct 23, 2007 | 07:21 PM
Taterdog's Avatar
Taterdog
Default RE: OIL
As said earlier, use the search engine. There's more than you could ever want to know about oil and filters for your bike.
Old Oct 23, 2007 | 07:42 PM
glide's Avatar
glide
Default RE: OIL
I wouldn't use 20/50 of any brand in the trans, that's MOTOR oil.
If you really want to see an improvement, try this in the trans. I changed from M1 75/90to this and can't believe the difference.
[IMG]local://upfiles/8308/EA5733B56D19433592183FF76A59A217.jpg[/IMG]
Old Oct 24, 2007 | 05:05 AM
PapaTravis's Avatar
PapaTravis
Default RE: OIL
I use amsoil 20w-50 in the engine. Amsoil severe 75w-90 in the trans, and either amsoil 20w-50 or hd formula + in the primary. the primary does not need sybthetic oil, and formula + is cheaper and works just fine. The last time I talked to my amsoil guy, he told me about the 75w-110 for the transmission. I will be going to that on the next change, I believe.
screamer56
Mar 31, 2014 01:53 PM
128auto
Jun 23, 2011 08:06 PM
pjbolo
Oil Archive (no new posts)
Jun 19, 2007 11:11 PM
carsoni
Jun 26, 2006 12:31 PM
MB
Jun 30, 2005 04:36 PM
