seafoam
Old Nov 23, 2007 | 07:07 PM
joe v's Avatar
joe v
Default seafoam
when seafoam is added to the motor oil does it thin the oil or can you add it and leave it alone or does the oil need to be changed.
Old Nov 23, 2007 | 08:16 PM
voodoodrug's Avatar
voodoodrug
Default RE: seafoam
I would try to contact the mnfg ? I went to store a bike and just put fresh oil in it and turned the engine over (with the plug wires detached) a few times,then put it on a lift. well a yr or so later I got rid of it anyway for more room in my garage. It can sit for decades like that. just remember air filter will self distruct and clog intake even if it was new,over long periods of time.
Old Nov 23, 2007 | 08:27 PM
jag1886's Avatar
jag1886
Default RE: seafoam
What's with all the Sea Foam questions? It's a fuel stabilizerplease don'tput it in your Harley oil bag.
On the other hand if you're putting it in your 52 Desoto thatstill uses non detergent 30Wgo ahead.
Old Nov 23, 2007 | 10:22 PM
jeepster09's Avatar
jeepster09
Default RE: seafoam
ORIGINAL: joe v
You can use it in your oil and in your fuel tank. Adding it to your oil in my opinion is best around 500 miles before a change to clean out a dirty motor. If you change regularly it is not neccessary though. It also works good to suck some through a vacuum hose once in awhile if you get carbon buildup on valves and pistons, it'll clean out the carbon.
Old Nov 24, 2007 | 09:24 AM
dchoran's Avatar
dchoran
Default RE: seafoam
Check this out - direct answers from SEA FOAM:
https://www.hdforums.com/m_2475171/m...tm.htm#2475192
I have used it in both two and four wheel vehicle's OIL [:-][:-][:-].
Even with fresh oil, if you add Sea Foam to it and your engine is dirty, the oil will go black in a matter of a few miles. Check out their comments on thatbulletin that covers oil "color".
So those who say you are wasting your money are WRONG unless you have a perfectly clean engine.
Many of us have PCIII's or SERTS's which richen up the AF mixture to cool off our engines - that in turn leads to more internal carbon.
All of the above comments were verified thru a Mechanical Enginner HD employee/friend of ours. He uses Sea Foam in his gas AND oil religiously. [:-][:-][:-][:-][:-][:-][:-][:-][:-][:-]
Old Nov 24, 2007 | 10:58 AM
ezgo's Avatar
ezgo
Default RE: seafoam
Been using Sea Foam in fuel for years, you can ride with it and also store your bike with it. NADA sells it.
cajun1957a
Sep 10, 2016 08:35 AM
a21m
Mar 11, 2014 06:55 PM
oct1949
Jul 8, 2012 02:20 AM
jcallesano
Jul 30, 2010 12:58 PM
dexterdave
Mar 18, 2009 02:59 PM
