Fuelpak mounting
Old Dec 7, 2007 | 08:42 PM
Drew's Avatar
Drew
Default Fuelpak mounting
Anybody have an issue with the screws used for mounting the Fuelpak to the spider bracket?
Mine were extremely tight going in, and one of the heads twisted right off. I went ahead and finished the install, and programmed the unit.
It seems to be mounted solidly enough with three screws. An email sent to Vance and Hines won't be answered until Monday, so I figured I'd ask the collective here if someone has run into the same issue.
Old Dec 7, 2007 | 08:55 PM
DCRANER's Avatar
DCRANER
Default RE: Fuelpak mounting
ORIGINAL: Drew
I did the FuelPak last week. Bottom line, I could have done an engine swap on an old muscle car easier than mounting that thing. The screws are too long, first thing in instructions should be "discard supplied screws, go to hardware store and but 4 small / short screws".
Old Dec 7, 2007 | 09:17 PM
HSdropout's Avatar
HSdropout
yes...snip off 1/8" and make sure you have right sized phillips....they shoulda used torx...
Old Dec 7, 2007 | 09:34 PM
Drew's Avatar
Drew
ORIGINAL: woody johnson
I thought about that, after the fact, but I'm afraid that I'll either strip the heads of the remaining screws, or crack the case.
Old Dec 7, 2007 | 10:01 PM
Lost1's Avatar
Lost1
I twisted off one of my spider-mount screws as well when I mounted it about 6 months ago. No biggie- other than that the install went quick and the FP works as advertised.
Bought a set of those Nightrider EFI enrichener devices advertised here: http://www.nightrider.com/parts/catalog00.htm
and will be installing them tomorrow on my EGC and the OL's Softail. It'll be interesting to see how they work as compared to the Fuel Pak.
If they work good I may have a FP for sale soon...
Old Dec 8, 2007 | 12:16 AM
Bond 007's Avatar
Bond 007
Yip. Had same problem. I could not get at least 1 of em all the way in. Had trouble with all of em. Decided it was secure thoughand finished the install.
07 Fire Red/Black Pearl Ultra
K&N 3909 A/C
V&H Ovals, Fuelpak
Old Dec 8, 2007 | 12:39 AM
unclekunkle's Avatar
unclekunkle
Yeah...they're too long and too tight...went to Sears to get a warranty replacement of my hardened tip #1 philips head in order to complete the screw job without f*#@'n up the heads! Aside from that everything else worked as advertised though...
Old Dec 8, 2007 | 12:44 AM
rgrecco's Avatar
rgrecco
Get a '08 Touring bike and you don't need to deal with spider brackets...
You connect it and velcrow it to the fuse box cover... no screwing except to hold the plastic cover on the FuelPak...
RON
WeimaBrewer
2014-2024 Touring Models
Aug 4, 2017 08:37 AM
ThaGlyde
Softail Parts
Dec 10, 2015 07:13 PM
apetterez
Apr 8, 2015 02:06 PM
TheJimer
23
May 8, 2009 07:22 PM
DGlide04
May 6, 2006 09:00 PM
