i have rush slip ons 2' baffles and was thinking about installing vance and hines fuel pak myself along with SE stage 1 air kit. anybody have a similar setup? hard to do? seems pretty straight forward for FP, what about air cleaner kit? Don't want a ball busting, couldn't find what i wanted in 'search'. Thanks guys/gals
Personally, I would go with the PCIII. I had the Fuelpak and didn't care for the performance and lackluster (at best)tech support. Jamie at FuelMoto has a good reputation. Same type of set up and an easy install from what I've heard. Search Fuelmoto, and read up on it.
easy set up with the fuel pack and air cleaner. i have the fuel pack it works great does what it should, but no fine tuning. if you get a dyno nobody can adjust it. meaning nobody know what each ov the values mean. yo uwould have to take your results and send them to V&H have them look it over and if any change needs to be made. they will get back to you with the changes.
Love the fuelpak, have had no need to adjust it. If your looking at engine mods down the road, you may want to go with something else with more adjustibility. My .02
Had the SE Stage 1 intake and FuelPak on my '07 Road King, but different mufflers. Was very pleased with the performance. The install of the intake and FuelPak are simple and they are effective upgrades. You'll want to be sure that V&H has a map for your pipes; if they do, then programming the FuelPak is very straightforward and will only take a couple of minutes after the install.
