Replacement Running Lights
Old Jan 16, 2008 | 11:38 PM
ninetyfivebravo's Avatar
ninetyfivebravo
Default Replacement Running Lights
I saw a post recommending GE 4509 aircraft sealed beams as a brighter replacement bulb for running lights. I found them on an aircraft supply site and the specs are as follows:
GE4509 100w 110,000cp 13.7v25 life hrs $10.75
Q4509100w140,000cp13.7v100 life hrs $24.75
Has anyone used them? How do the specs look? I have a question on the voltage being 13.7 and the bike having a 12v system. Does anyone have any input or warnings about these buldbs?
I'm trying to get more light to the front both in daytime and night.
Old Jan 17, 2008 | 03:59 AM
Captain Itch's Avatar
Captain Itch
Sponsor
Default RE: Replacement Running Lights
As I live out in the country I have played around with adding some very bright driving lights,the deer and roadkill situation is crazy Let us know what you find...
__________________
www.Captain-Itch.com
Old Jan 17, 2008 | 09:38 AM
Olde Skool's Avatar
Olde Skool
13.7 is in the normal range while the engine is running. Pretty much the same as a cage electrical/charging system.
Old Jan 17, 2008 | 09:39 AM
rjmac53's Avatar
rjmac53
good to know
Old Jan 17, 2008 | 09:48 AM
Neil's Avatar
Neil
I would think that 100w is too much for the spot lamp wiring to handle. I would be willing to bet the wiring would melt/burn etc...
Just my $.02 worth.
Neil
Old Jan 17, 2008 | 11:24 AM
bdaug50's Avatar
bdaug50
Take a look at the PIAA bulbs. I haven't used them so I don't know what their life span is but I recall seeing some replacement bulbs, for the headlight at least, that were well above the standard output. I would be careful looking at the Sylvania Silverstars, I used them in my pickemup truck and they didn't last more than about 3 months. They were bright, but at the cost of lifespan.
Old Jan 17, 2008 | 11:28 AM
xxxflhrci's Avatar
xxxflhrci
I used 100 watt aircraft landing lights for a while. They were too blinding for other drivers.
I swapped to 35 watt unfluted bulbs. They are just like the stockers, except they have clear lenses, which shoot a beam straight down the road instead of dispersing it to the side.
You can get either bulb from NAPA or Tractor Supply for about 9 bucks each.
Old Jan 17, 2008 | 08:04 PM
ninetyfivebravo
Besides the voltage, which is a non-issue, I was concerned about on coming traffic and how the landing lights would affect them. I will try the 35w bulbs.
Thanks for the input.
08ClassicRider
Electrical/Lighting/Alarm
15
Jun 17, 2019 09:18 PM
mayhemmaster
13
Sep 26, 2014 05:40 AM
Y2JAPA
Feb 17, 2013 05:11 PM
fabrik8r
Aug 21, 2011 10:18 PM
rhbuilds
Jun 19, 2008 07:20 AM
