WTF ?
Old Feb 5, 2008 | 07:36 PM
GliderXXX's Avatar
GliderXXX
Default RE: WTF ?
ORIGINAL: MIHRULES
ORIGINAL: FastHarley
My friend Luis does em way chaaper than that! He is a certified and trained HD machanic for <30 years. Sorry, you just got opened like a double barreled shotgun! Just got done with a 113 evo for me. All I can say is I am sorry for you. Do you know how many cheap dates that cost you?
Well here's what pisses me off so bad. After the build (AFTER) He tells me i will only get around 40K out of the engine build and i only have a ninety day warranty. I called Harley and they said it was between the store and me, but the bike warranty was void now. I cant tell you how pissed i am for this. i lost my warranty and got riped.
Your dealer really really sucks bad. First he's full of it re: the 40K out of the motor...nonsense. The 90 day warranty issue I'm afraid IS between you and this jerk. All that said, you should be able to get your bike tuned to run pretty damn well. No point in not going ahead and making the best of your motor. It's not like you have a pile of junk.
Old Feb 5, 2008 | 08:07 PM
tom73's Avatar
tom73
Default RE: WTF ?
Judging by the numbers I would have expected more but two items to consider:
1. How does it feel. Numbers are just numbers, Is it a flat torque curve, does it pull hard? If so don't sweat the peak number. I would rather have 8 less ft/lbs at a peak and have more in the 2500 - 3250 RPM range. Same with HP.
2. Do not discount the power of a good tune. Looking at your parts list I think you should have more there. You have good compression, good cams and I assume upgraded heads (can't speak how good those heads are) Look for a good tuner and I think you will find more power
Again don't sweat the numbers. It is how it feels. I have not dynoed my HQ build yet and would love to see how it does. Regardless I am pleased with the power increase even though I could always use more. Not to put salt in your wounds but I did my HQ build for $2300 but did my own wrenching. When you get it tuned by a better person let us know how you make out.
Old Feb 5, 2008 | 09:42 PM
cardboard's Avatar
cardboard
Default RE: WTF ?
Sounds to me like you didn't do yer homework good,
The dealer does a parts build. They are under the EPA guide lines also. Indy shops will also run away with you on parts and prices also.
The HP and TQ numbers can change according to what kind of dyno machine yer bike is dynoed on.
Talk to a head man and a Indy shop. I did a mild 103 build, already had a Good set of pipes. I came out for around 2600.00
Had 92hp and 103 torque. Went with the Thundermax with Auto Tune.
Ran a factory 110cu HD and made him ask, what did you do to yer motor.
Old Feb 5, 2008 | 10:56 PM
rockdoc's Avatar
rockdoc
Default RE: WTF ?
I wasn't thrilled with my dyno numbers either (low eights HP, nudging 100 on torque). My 103 (HD build) is definitely much better that stock but I think the tuner could have done a better job. I'm gonna take it to an independent guy down the road after I put a few thousand more miles on it. I did get a good deal on it (30% off parts and labor as part of a fall special) so I don't feel ripped off.
Old Feb 5, 2008 | 11:15 PM
cardboard's Avatar
cardboard
Default RE: WTF ?
ORIGINAL: rockdoc
If you got a 103 harley build, they probaly didn't do nothin with yer heads left them stock. you probally just got jugs and pistons. Did they do cam's, and if so which ones.
Old Feb 6, 2008 | 12:05 AM
heywood727's Avatar
heywood727
Default RE: WTF ?
I believe they are the 255's in the 103's and your right... no heads. That comes with the 110 build from them.
Old Feb 6, 2008 | 06:28 AM
miacycles's Avatar
miacycles
Default RE: WTF ?
Get some heads or headwork and wake that motor up. An engine is just an air pump, the more air you get in and out of it efficiently the more horsepower/torque/smiles you will get. You can get some good head work done by some of the site sponsors for a very reasonable price, you should check them out.
Old Feb 6, 2008 | 07:26 AM
cardboard's Avatar
cardboard
Default RE: WTF ?
ORIGINAL: heywood727
The best cams HD has are the 258's. I'd rather have a Andrews, or Woods cam. Choose the cam according to how you git the heads done and what RPM you want them to work. I would try to stay with a low compression build.
Hope the dealer put SE flat top pistons in.
But yer motor is still not breathing and could be woke up.
Old Feb 6, 2008 | 09:27 AM
jakester's Avatar
jakester
Default RE: WTF ?
THAT SUCKSSSSSS!!!!!!!! Hope you have Good Luck and everything works out OK for you!!!!! [sm=bs.gif][:@][sm=wtf.gif][sm=WTFsgign.gif]JAKESTER...TIM...
Old Feb 6, 2008 | 10:57 AM
MYHRULESS's Avatar
MYHRULESS
Default RE: WTF ?
ORIGINAL: SMUNDORF
Lots of research necessary before we make changes like that. Especially if we let the dealer play with our bikes... I was pissedat whatI paid for the stage one download and for the dealer to install slip ons. It was a waste of money to have them do anything. Oh well if I knew then what I know now... Next time I will be wiser
Well to be honest, I thought I could trust the dealer. I thought if there was anyone i could trust , it would be a dealer. I was wrong. sense i have done my homework and did a lot of research. Im here to tell you right now, never trust a dealer. they have their best interest at heart and they will get what they can out of you. And if anyone thinks they get a warranty with a harley build. Call Harley and ask . You're warranty is void. Now if your Dealer hides it from Harley, that's another case. I wont make the same mistake twice.
