Security System Programming
Old Jan 26, 2006 | 02:53 PM
dhutchison's Avatar
dhutchison
Default Security System Programming
Does anyone know if you can program a new key fob to the security system module without having to go to dealer? It's on an 05 FLHRCI.
Old Jan 26, 2006 | 03:32 PM
Bruce00's Avatar
Bruce00
Default RE: Security System Programming
1)Turn ING key On-OFF-ON-OFF-ON
2) Press left turn switch 2 times and release
2 flashes of turn signals and indicators for North America
3) Press right turn switch 1 time and release
1 flash turn signals and indicators
4) Press left turn switch 1 time and release
5) Press and hold key fob button until you get confirmation
2 flashes turn signals and indicators
6) If you have 2 key fobs, press and hold button on 2nd key fob until you get the confirmation signal.
2 flashes ts and ind
7) Turn ING key off
Hope this helps
Old Jan 26, 2006 | 05:54 PM
Traderjoe's Avatar
Traderjoe
Great post!
How do you program the security system through the turn signals in case your Key fob stops working? I still have to do that.
Old Jan 26, 2006 | 05:57 PM
UltraScoot's Avatar
UltraScoot
ORIGINAL: Traderjoe
Great post!
Me Too.... but was wondering if already done at the dealer?
Old Jan 26, 2006 | 10:46 PM
Roadie 49's Avatar
Roadie 49
You'll need to put in your own personal code. It is five single numbers [ 1 - 9 ]
Use left and right directional switches in a certain sequence to install.
Just did my 06 RK. Owners manual will tell you what you need to know.
There is a wallet size personal code card in the owners manual. Fill it out
and stick it in your pocket, just in case you forget your code, or how to do it.
Old Jan 26, 2006 | 10:56 PM
HDF Tech's Avatar
HDF Tech
You can find most of the answers here... https://www.hdforums.com/forumid_247/tt.htm
Old Jan 26, 2006 | 11:48 PM
dhutchison's Avatar
dhutchison
Thanks for the info. Big help!
Old Jan 27, 2006 | 02:06 PM
Bruce00's Avatar
Bruce00
ORIGINAL: TCSTD
This place has all the answers!!!
Especially with TC pointing the way[sm=happy046.gif]
bubbadukie
20
Jan 15, 2023 09:51 PM
21pungo
Jun 13, 2015 11:39 PM
ebartman
Jan 30, 2013 09:25 AM
grimminator
Feb 10, 2008 01:42 AM
CCPD
Jul 21, 2007 04:14 PM
