use this link instead of the one you have.. u just copied the wrong link from photobucket.. it should be the second link under the picture.. u copied the first...
I found for some reason I have to resize the picture,save it somewhere else, than reload the resized picture to photobucket. Than copy the "direct link" of the resized picture.
Whenever you go to put the [IMG][/IMG] tags on your pic, put the cursur at the end of your address andBACKSPACE once, this removes the address as a clickable link, THEN put the rear [/IMG] tag on your address.
