Recommend some bars...
Old Mar 17, 2008 | 08:48 AM
ShortyK's Avatar
ShortyK
Default Recommend some bars...
Being as short as I am, I find myself leaning forward on the bars when riding. This causes funny things to happen with the steering as you can imagine..
I need a set of bars that are about 1" taller and swept back about 2"
07 EGC
Suggestions?
sK
Old Mar 17, 2008 | 08:54 AM
Secretec's Avatar
Secretec
Default RE: Recommend some bars...
Check Krome Werks out. They have sweeper bars that may work.
kromewerks.com
Old Mar 17, 2008 | 08:58 AM
Secretec's Avatar
Secretec
Sorry, this is it.
http://www.khromewerks.com/
300505-300505 1" +2 Taller Sweeper Bar for 1996-2007 FLHT M.S.L. $63.99 (Requires 3" over clutch cable) Now in stock – order factory direct (952)758-9523.
--300505 1" +2 Taller Sweeper Bar for 1996-2007 FLHT M.S.L. $63.99 (Requires 3" over clutch cable) Now in stock – order factory direct (952)758-9523.
Old Mar 17, 2008 | 09:17 AM
CNC WHEEL GUY's Avatar
CNC WHEEL GUY
ORIGINAL: ShortyK
07 EGC
Suggestions?
sK
SK:
Not sure how short you are, but I am 5'6" (consider myself short). Anyway, believe it or not a mild set of 12" - 14" apes mght be just right for you. I got ride of back/neck pains by going to my first set of 14" apes.
I gotta worn you though, I changed 2 more times, went to 16", and now 18" Gimp Hangers on my Softail. If it wasn't fpr the pain in the *** fairing on my Streetglide, I'd have 13" on that too!
Old Mar 17, 2008 | 10:10 AM
nmfxstc's Avatar
nmfxstc
There are some cool places in St. Louis near the river...no cover or minimm...ummmmmmm....WAIT....I misunderstood....never mind!
Old Mar 17, 2008 | 10:17 AM
Peppa1's Avatar
Peppa1
You might want to look at the dresser bars made by Wild1's. They have nice bars that are up and back also.
Old Mar 17, 2008 | 11:13 AM
Whiskers's Avatar
Whiskers
Call the tech's at Wild 1....they were really helpful when I needed a new set. They make some great looking bars as well...may be a little higher ($) but are well worth it.
Old Mar 17, 2008 | 11:49 AM
IronButt62's Avatar
IronButt62
+1 on the Khromewerks 2" over sweepers. Put a set on this winter and they are very nice. Pull back about 2" and up a bit. Also a couple of inches wider than stock. Keep my hands behind the fairing as well. Soos had some pics up back in December. Can be installed without cable/wiring mods if you are willing to route your clutch outside the fairing. Otherwise the 3" over clutch cable from Harley makes it work fine. I put the 3" over throttle and idle cables from Harley as well but didn't really need them.
Bars themselves are around $70. Beleive they are only available from Khromewerks direct for now. I also picked up +3" cables from Zanotti's for around $70 (clutch throttle/idle).
Significantlycheaper than some of the other options and they look great.
Deet
Old Mar 17, 2008 | 11:52 AM
nsodpty52's Avatar
nsodpty52
a set of shorty apes, I have the 16's and I'm 5'9" I reach them fine.
Old Mar 17, 2008 | 03:46 PM
billybobsrk's Avatar
billybobsrk
Check our the W0575 handlebars from Chubby Wild Ones; if you've got a question give them a call or email them.
http://www.wild1inc.com/handlebars.html
