problem
Old Mar 21, 2008 | 07:50 PM
johnnyb3667's Avatar
johnnyb3667
Default problem
ok today i was cleaning my RK custom and i went to move it (not running) and when i tried and pulled in the clutch it was like it wasnt engaging and wasnt moving. i havent road the bike in about 3 weeks but never had a problem before this, it wouldnt move in any gear then i started it and let it warm up for about 10-15 min and nothing changed then i tried to start it in 1st gear with the clutch engaged and it pulled the bike foward like i wasnt pulling in the clutch then went away and started and now seems to be ok. i checked the cable and everything looks and seems ok i just cant think what could of caused this to happen and do you think i might have a problem again... thanks for the help.. sorry if it seems confusing
Old Mar 21, 2008 | 07:54 PM
rsofa's Avatar
rsofa
Default RE: problem
Mine does the same thing I think it's normal!! HA I could work for Harley!!!!!
Old Mar 21, 2008 | 08:08 PM
2008FLHP's Avatar
2008FLHP
Default RE: problem
oof dont know but that sucks
Old Mar 21, 2008 | 08:18 PM
johnnyb3667
Default RE: problem
and im not sure if im gonna burn out my starter trying to start it everytime this happens and drain my battery
Old Mar 21, 2008 | 08:22 PM
Bill03E's Avatar
Bill03E
Default RE: problem
it's ok ,the oil is running out of the clutch,and the plates are "sticking together" normal thing when they set.
Old Mar 21, 2008 | 08:24 PM
o5ultra's Avatar
o5ultra
Default RE: problem
the cold weather could be causing your clutches to stick fluid id thicker making clutches to bind to gether should be ok when it warms up
Old Mar 21, 2008 | 08:25 PM
johnnyb3667
Default RE: problem
ok cool thanks guys now i feel a little better
SoCal_Pappy's Avatar
SoCal_Pappy
Default RE: problem
NORMAL... Agree!
Old Mar 21, 2008 | 08:59 PM
TexasRedneck's Avatar
TexasRedneck
Default RE: problem
Ditto on the normal.....
Old Mar 21, 2008 | 09:06 PM
8upFLHRI's Avatar
8upFLHRI
Default RE: problem
my 03 does that too
